VALVOLINE MaxLife?
Old Dec 17, 2016 | 07:39 PM
therhett17's Avatar
Default VALVOLINE MaxLife?
Hey guys, I've got a '97 4 cyl with 269k miles. I've been using Pennzoil conventional 5w-30 since I've owned the car, so for about 8 or 9 oil changes, but I'm thinking about switching to a high mileage oil the next change in an effort to reduce minor oil leaks and consumption. I know Pennzoil has a good HM oil but I've been looking at MaxLife (the synthetic blend) and have heard good things. Would it be bad to run a synthetic blend in a car with such high miles, even though it's a high mileage oil?
Old Dec 17, 2016 | 07:57 PM
nus_dogg's Avatar
Default Re: VALVOLINE MaxLife?
I would keep it conventional with that high of mileage.
Old Dec 18, 2016 | 07:32 AM
holmesnmanny's Avatar
If you have leaks the synthetic is going to make the leak worse. Either fix the leaks and run that or run high mileage to slow the leaks.
Old Dec 18, 2016 | 08:44 AM
Aradin's Avatar
Premium Member
Synthetic blend isn't the same as a full synthetic guys. MaxLife is fine to use on high mileage applications. I regularly service a 94 Accord that's still on it's original engine and transmission with over 400k miles that has been using 5w30 MaxLife for as long as I can remember. You will be fine OP, it's a good oil.
Old Dec 18, 2016 | 09:10 AM
nus_dogg's Avatar
I know that. If it was me, I'd keep it conventional. That's just me though.
Old Dec 18, 2016 | 12:08 PM
therhett17's Avatar
Thanks for the replies y'all. It's not leaking oil bad enough to puddle on the ground or anything, more just seeping enough to make a mess on the undercarriage and maybe an occasional drip. Most of the oil is being used. Didnt wanna make the leaks worse with synthetic tho but maybe a blend won't hurt? So should I go with that or Pennzoil High Mileage?
HA0589
31
Mar 5, 2014 09:09 PM
newbie2012
Oct 26, 2012 04:23 PM
spartans2
Oct 19, 2010 10:24 AM
Mindtrap
Sep 3, 2003 09:14 PM
G2_Integ
Aug 11, 2001 09:13 AM
