B16A swap pushing too much fuel?
Old Dec 16, 2016 | 09:28 AM
TristanMcArthur's Avatar
Default B16A swap pushing too much fuel?
im pretty sure it is fuel since my oil and coolant levels remain normal with no abnormalities of consistency or coloration, but I believe my car is having an issue with its swap. I bought the car with the swap done to it. Has 5 speed gsr transmission as well. I got a "new" p28 ecu and wiring redone after I bought it so it would run decently. Retuned with a basic Hondata tune and since then has been pushing fuel smell majorly out exhaust. Some white smoke as well. When in idle, it bogs down from 850rpm to 400rpm when any electrical loads are added. Throws a fit when fuel pressure is at 42psi versus 36 right now. Need help
Old Dec 17, 2016 | 07:56 AM
fcm's Avatar
fcm
Old Fart
Default Re: B16A swap pushing too much fuel?
Check ECT sensor and it's wiring, you may be running rich. 94
Evan Owens
Oct 8, 2017 11:58 AM
s1ngleslam
Oct 21, 2008 12:37 AM
shadowstylz
Jul 27, 2003 07:27 AM
slow02ss camaro
Feb 1, 2003 07:44 AM
