Stubborn misfire cylinder 3 2000 Accord EX
Old Dec 15, 2016 | 12:05 PM
8888's Avatar
Default Stubborn misfire cylinder 3 2000 Accord EX
Car is a 2000 Accord EX with 170k miles on the VTEC 4 cylinder that has a pesky misfire CEL for cylinder 3. Bad enough that extended idle time will make it flash and only cylinder 3, but the car runs reasonably well and gets 29mpg in mixed driving.. One owner car with lots of service records, regular maintenance.
Wires, cap and rotor are Denso and less than a year old,
Coil and NGK plugs are new.
Distributor shaft checked for play.
Valves recently adjusted and compression checked.
Timing belt done 15k ago.
Currently at a local shop and they can't find the cause, I suggested injector, seals, and harness and they said they checked those.
Checking around, cylinder 3 seems to be common but I haven't seen exactly why. Usually something on the list above sorts it out but no luck so far.
Any ideas what else it could be?
Thanks
Old Dec 15, 2016 | 03:38 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Stubborn misfire cylinder 3 2000 Accord EX
Partially clogged EGR port would cause a lean misfire but not enough to cause P0401(insufficient EGR flow) to be triggered.
Old Dec 15, 2016 | 04:04 PM
8888's Avatar
Thanks, sounds like something to attack next!
Old Dec 15, 2016 | 06:21 PM
MAD_MIKE's Avatar
MM Gruppe B
Bah, EGR would NOT affect idle though.
Verify that the spark plug boots are sealing properly. Prestolite and Sumitomo are the OEM plug wires. NGK is acceptable fit and finish, other brands may or may not fit correctly. Cheaper wire sets are known to have the boot pop off or not fully seat and cause a misfire condition.
Verify there is no oil in the spark plug tubes.
Swap the plugs around, if the misfire follows the plug then it is most likely the plug that is at fault. Verify the plug gap on #3 is not excessive or shows wear/damage.
I've had new plug wires be bad out of the box, beg/borrow/steal another set.
Old Dec 15, 2016 | 09:56 PM
holmesnmanny's Avatar
You can try swapping the fuel injector with another. See if the misfire follows it.
Old Dec 25, 2016 | 04:01 AM
8888's Avatar
It ended up being a leak at the intake. The shop smoke tested it after swaps of other bits didn't fix it. .
They replaced the downpipe and intermediate pipe as well due to corrosion and now i have a p0420 for bank 1. Good times!
Bebo01
Aug 6, 2018 08:09 AM
HeresOtis
Nov 10, 2017 01:21 PM
Dabears
Jul 4, 2016 06:48 AM
gimphand
Oct 11, 2013 06:12 AM
Smitty2000
Mar 23, 2008 09:51 PM
