Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
M/T in an Odyssey daily
Old Dec 10, 2016 | 03:03 PM
smilindave's Avatar
Default M/T in an Odyssey daily
I am curious if anyone has done this and is it possible for use as a daily. I don't like automatic transmissions, the last vehicle I owned that had one was a real problem. This is why I am seeking information as I have seen exotic builds but nothing for daily use. I would like like to use a MDX engine due to the 3.7L displacement and 300 hp from the factory. The cars I have are swapped EF's and I find them to be fun to drive and not problematic to change powertrains and/or drive as daily transportation. They are simple and fun to drive. I am 54 and have done the work on the cars myself. The goal is to have a vehicle that I can travel in and carry stuff. Automatics don't appeal to me at all, so I am trying to find if this can be done with a reasonable amount of work and money. I realize that the transmission will be the expensive piece of the puzzle. What else will I need as far as shifter, pedals and ecu? Anyone able to help will be appreciated.
Regards
Dave
Old Dec 21, 2016 | 02:23 PM
smilindave's Avatar
Default Re: M/T in an Odyssey daily
Aww, come on, no one has an opinion or ideas on what might work?
Regards
Dave
Old Jan 3, 2017 | 04:48 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I don't think the tranny will be the expensive part as there are TL-S trannys out there that would bolt to the J series V6. I'm not sure it will be so much expensive as it will be time consuming, and mostly one-off stuff for clutch lines, pedal assembly/brake pedal assembly work, shifter box, etc.
You never mentioned exact year model or even generation of Odyssey - which one are you looking at? That will determine a lot of things.
Old Jan 3, 2017 | 09:14 AM
tony_2018's Avatar
Fish Twig
Its been done before....just not on a wide scale. I believe the only person whose done it was bisi with his turbo honda odyssey.
xotic_crx
Oct 13, 2015 07:17 AM
Race Egr
Welding / Fabrication
25
Aug 10, 2009 08:51 AM
papagnoj
Jul 30, 2009 03:10 PM
tortis
19
Jul 14, 2007 08:21 AM
ActiveAero
12
Oct 2, 2001 09:28 AM
