1998 Honda Civic DX - Overheating Mystery
Can't figure this out for the life of me, hoping someone here has had a similar problem/experience and can maybe point me in the right direction on what to do next. The car seems to run fine, but will start overheating after 15-20 miles. Here's a list of things I've done/noticed.
- Changed thermostat (Honda OEM)
- Changed Thermostat Fan Switch (Beck-Arnley) fan is working now, it wasn't working when I originally noticed it was overheating, but even working the car still overheats
- Changed water pump (Old one looked fine tho, but it was overdue for a timing belt change anyway)
- Radiator is only a year old, had a small leak in it last year and replaced (Napa radiator with Napa radiator cap)
- Flushed the radiator and upper/lower hoses when I did the timing belt.
- Did a combustion gas test multiple times, came back negative. Fluid seems good tho, reacts to car exhaust/exhaling.
- Radiator is still filled with coolant when I did the water pump change (2 weeks ago)
- Car heat works fine
How do you know the car is overheating? What tests have you done to rule out faulty coolant temp sensor and/or wiring, or faulty dashboard gauge/wiring?
Also, what it your coolant temperature and how did you measure it?
Finally, how did you purge the coolant system of air?
2. I haven't measured the coolant temp with a thermometer but it is definitely hot to the touch (coolant hoses) and will steam with the radiator cap off, etc.
3. Parked on an incline, heat to max, radiator cap off, let it idle for a long time 30+ minutes, topped it off as it went down (didn't take too much additional coolant but it did take some). I've done this multiple times, sometimes letting it idle, sometimes putting it at 1000-1500 rpm for a bit and then letting it idle.
The best way I can think of to test the dashboard temp gauge is to point an IR gun at the radiator and/or hoses and read the value. Compare that with the coolant temperature reported by your gauge and by the PCM using a scan tool. Low-end version of both pieces of equipment can be found for ~$20 each.
Another way to look at it: imagine your dashboard temp gauge is bad. How much trouble is it going to cause you to continue relying on it?
I don't know if that's the problem, but I'd be interested in gathering as much data as I could before changing any more parts.
Is the top hose hot and bottom hose cool [hot but cooler than the top hose] at operating temperature? That's how it should be. An inefficient radiator could give you a hot hose on the return (bottom). A blockage could give you cold intake (upper) hose.
Is the top hose hot and bottom hose cool at operating temperature? That's how it should be. An inefficient radiator could give you a hot hose on the return (bottom). A blockage could give you cold intake (upper) hose.
edit; the radiator is only a year old, also
Is there anything else it could be besides a faulty sensor/wiring?
I have an OBD II scanner but idk if mine will tell me that info, i've only used it once to see a code years ago
https://www.amazon.com/BAFX-Products...AHS/ref=sr_1_1
Sensor on the thermostat housing is the fan switch
Sensor on the front of the cylinder head Infront of the dizzy is the ecu temp sensor
The sensor under the dizzy mid way back on the head is the gauge sensor
I would suggest replacing the gauge temp sensor first.
What is a dizzy.
dizzy is when you spin around long enough to fall over.
http://www.ebay.com/itm/Richporter-Technology-HT04-New-Distributor-/192025068183?fits=Year%3A1998 Model%3ACivic&hash=item2cb5960297:m:mnSICX2MXae58d 1oAqA1eUw&vxp=mtr
OP, have you checked the level of coolant after overheating? Is it leaking anywhere? You can check the resistance of the coolant temperature sensor with an ohmmeter, I don't remember off the top of my head what the readings should be but google should have that answer for you. If it is out of spec, replace it. If not, you're looking at a possible leaking head gasket.
I just had this problem OP. You either have two issues here. Fan control relay or the temp sensor on the side of the head. Both are cheap and easily done so I would recommend replacing both, since you have basically over-hauled your cooling system already. Change the coolant temp sensor that's on the cylinder head. Fans come on late, but only after car begins overheating? My situation, I had recently over-hauled the whole cooling system. Had over-heating issues after few thousands miles later. Basically the temp sensor is shorted. Telling you car's ecu that the temperature is lower than it really is. In turns not letting the fans come on. Hope this helps, this one kicked my butt. Only because it was a combination of the fan relay and this engine temp sensor.
Correct, the guy who said the top should be hot and the bottom cool is wrong. That's indicative of a bad thermostat.
A warmer upper hose doesn't necessarily mean anything is wrong with the coolant system or engine.
yes, it does. once the thermostat opens, the hoses are nearly the same temperature... nearly as in your hand wont know the difference.
edit; someone above you said I should change the sending unit sensor first, maybe I should just change both to be safe lol.... they're not cheap tho :\
So change the ECU sensor on the head, not the sending unit to the gauge? Man I will be pissed if it was only that sensor... also extremely strange if it is the case, replaced an o2 sensor about a month ago, fan switch sensor, and now this? What is causing all these electrical problems.... Also shouldn't that sensor be throwing a check engine light if its bad?
Also I would purchase a laser temperature gun also available at any auto parts store or harbor freight to take a reading of the temperature of the cylinder head by the distributor to see if it's actually over heating.
You could also have a clogged heater core if your heater isn't working.
Giving me **** about calling it a dizzy lol. Comon man I can use slang terms
The sensor is cheap. I got mine for 7$ on eBay , here one for 15$ FAE brand is an OEM vendor for a lot for German brands i.e. VW, BMW . So it is a quality sensor. http://www.ebay.com/itm/FAE-37870PJ7003-Engine-Coolant-Temperature-Sensor-/121958098107?hash=item1c6544e4bb. The relays are about 15$ a piece pricey for a relay, careful Honda will charge you about 40$ for the "Newer" vendor. But the old stock ones are about 10-15$ you just have to research the part #s
The fan switch can be an issue, I saw that you purchased an aftermarket one. With parts like this I would recommend to stick with OEM, I've learned this from trial and error. Aftermarket tends to be cheaper because the NTC inside the sensor is a cheaper one and doesn't have the same specifications as the OEM one. Which can cause your fan to turn on but too late causing the temp to "overheat". You can take the cheaper route and it may work but not all the time. I've had a fan switch brand new from Autozone shorted internally and as soon as ignition was on the fan was on and never turned off, also as stated previously I've had one that didn't have the correct thermistor installed and the fan would only turn on when the car was overheating.
logansuttle
Apr 13, 2017 05:24 AM
diamondwhite50
Jun 17, 2007 09:51 PM
