Jdm b18c swapped Em1 no rpm?
Hello I have a 99 Civic Si that has a jdm b18c swap. It has the factory obd2b Si wire harness and has a jumper harness to a obd2a p72-013 ecu. the tachometer (rpm) guage was working perfectly until my Distributor went out. So I replaced it with an aftermarket ebay distributor. the car runs again but no tach? could it be the icm is faulty? I tried to run a jumper wire straight from the distributor blue wire to the back of the tach and still didn't work. but if I unplug the jumper harness and p72 ecu and I plug in the original stock b16a ecu the tach works fine. so I feel like my issue lies in the distributor? just doesn't make sense it would work perfectly, then when I replace the distributor it stops? very odd! crazy electrical problems! 🤕😝
Okay so I did a bit of research online and the only thing I could come up with was running a wire directly to the tach wire on the back of the dash cluster. so when I did that I just spliced into the blue wire and did not cut it off from the tach. when I did this the tach still didn't work. so I cut the wire off and now it works. idk why my tach stopped working when I put the new dizzy on but it works now with the jumper wire. stupid electric crap! haha!
Not sure but I think on the 99 tach signal from ICM went through the ECU before going to the cluster, I am guessing but if it works with the original ECU installed and no jumper that would be my guess.
I do not have a 99 wiring diagram with me to confirm tach signal routing. 94
4dooreg-k
11
Jun 23, 2006 12:50 PM
ozzyman
Sep 29, 2003 01:39 AM
ozzyman
