1991 ef sedan front brake options
Old Dec 5, 2016 | 11:00 AM
ssmrico's Avatar
Icon5 1991 ef sedan front brake options
looking to upgrade front brakes. car will make 600+ soon and well stopping power is a must specially at the track.
what are other brakes maybe from other Hondas that make a drastic difference from stock ones? if not after market ones?
Old Dec 5, 2016 | 12:29 PM
4drEF's Avatar
Keyboard Humorist
Default Re: 1991 ef sedan front brake options
For a direct fit, the sedan EX has large rotors.
Not sure what kind of track you are racing on, but for everything other than drag racing, you should be looking into a multi-piston caliper.
EX has the same rotor as the DA Integra and the Civic Si-R
If you need something bigger and want to keep the cost low, check out the kits from fastbrakes.
http://www.fastbrakes.com/Default.asp
Old Dec 5, 2016 | 09:26 PM
acmoc's Avatar
600hp? you should probably get the wilwood kit
Old Dec 6, 2016 | 04:20 AM
ssmrico's Avatar
yeah about 600 maybe more later
Old Dec 6, 2016 | 04:21 AM
ssmrico's Avatar
any specific person or vendor on here I should contact?
Old Dec 6, 2016 | 04:23 AM
ssmrico's Avatar
1990-2001 Integra 1 piston 10" drag kit
these for integra?
WWW.Fastbrakes.com
Old Dec 7, 2016 | 08:51 AM
4drEF's Avatar
Keyboard Humorist
You could use those on a DA knuckle.
DA knuckle fits the EF chassis pretty well.
This is what I was thinking -
http://www.fastbrakes.com/product_p/civicrl.htm
Old Dec 8, 2016 | 04:29 AM
ssmrico's Avatar
ok good to know. but not on the ef stock stuff right?
Old Dec 8, 2016 | 09:28 AM
ssmrico's Avatar
yeah car has da knuckles
Fastbrakes 1988-2000 Civic CX, DX, VX, 1988-1991 CRX, delSol S and Si with Acura RL caliper 11.8" adapter kit with rotors big brake kit
Old Dec 10, 2016 | 10:32 AM
boibuddha's Avatar
Since you have DA knuckles, you should be able to bolt on any BBK that applies to the Integra without using any adapter plate.
The only real limitation would be your wheel size.
Old Dec 11, 2016 | 05:43 PM
acmoc's Avatar
How much heavier are the bigger rotors from fastbrakes?
Old Dec 12, 2016 | 04:32 AM
ssmrico's Avatar
slicks are 13s
M3THTICAL(EF)
Suspension & Brakes
Mar 4, 2015 07:41 AM
darrenVT
Suspension & Brakes
Nov 2, 2008 09:00 AM
Nov!ce
Dec 18, 2004 07:26 PM
red civic standard
10
Jul 30, 2004 12:02 PM
88civicHB703
21
Jun 1, 2003 07:44 AM
