Suspension & Brakes Theory, alignment, spring rates....
Eg forks using function and forms
Old Dec 5, 2016 | 03:53 AM
Thategdude's Avatar
Default Eg forks using function and forms
I have an eg hatch. I'm using the function and form suspension but I can't get the front forks to fit the strut!! Anyone know what forks I can use to make them work ??
Move tried spreading them apart but the bolt doesn't match up!! Please help and big thanks in advance
Old Dec 5, 2016 | 07:10 AM
Tyson's Avatar
Default Re: Eg forks using function and forms
Previous owner must have used EF shock forks. Same height, smaller diameter.
What 2 letters are embossed on the fork?
Old Dec 5, 2016 | 11:41 PM
KiNGDEE206's Avatar
if your shocks are too thin in diameter and will slide on/off of your forks even when tightened.
THAT most likely means what above said ^^ u have EF/DA coilovers
U MUST get front forks off a "parting out" ef/DA @ junkyard $20-40 bucks
rears will fit perfectly fine plug n play
724chris
Jan 10, 2010 06:40 PM
superhatchbackbros
10
Feb 8, 2008 11:22 PM
UK_EG
Suspension & Brakes
Oct 4, 2005 03:05 PM
89dohcEF
Nov 8, 2003 11:58 AM
Lightning Lover.
Sep 28, 2003 03:26 PM
