Suspension & Brakes Theory, alignment, spring rates....
Wheel rubbing fender/frame wall question
Old Dec 4, 2016 | 01:50 PM
Timexlord's Avatar
Default Wheel rubbing fender/frame wall question
so I picked up a 97 civic coupe ex for a day to day beater car, the car was already lowered when I received it. It is lowered in shocks/springs unsure of the brand because I just picked up the car. From the looks of it the tires are way to big for this ride height 195/70/14. The tire barley rubs the outer fender/lip and splash guard, my problem is the rim/wheel rubs the inner wheel well frame wall and I can hear metal on metal when I try to make a turn, I'll post pictures once I leave work
Old Dec 4, 2016 | 02:03 PM
Timexlord's Avatar
Default Re: Wheel rubbing fender/frame wall question
Will post the the inner fender later
Old Dec 5, 2016 | 08:57 AM
Timexlord's Avatar
This is my main concern. I'm basically wondering if I need to get a different wheels, 15s with a more positive offset or do I need something else any info would help, thanks guys
Old Dec 5, 2016 | 01:00 PM
spAdam's Avatar
Loved
Community Favorite
Getting those balloons off of there will fix a lot of problems. Get the right size tires, stock is 185/65r14. Specifically you want to find a tire with ~23.1" diameter. Beyond that, the car is pretty low and there will always be a little bit of an issue at extreme steering angles.
Timexlord
Dec 6, 2016 08:17 PM
crxaddikt
Feb 9, 2014 05:53 PM
Finger Lickin' good
Oct 2, 2004 06:53 PM
Rydaddy
Apr 15, 2003 08:36 AM
