Need Help w/ 95 EX motor
Old Nov 8, 2002 | 08:10 PM
cvcc's Avatar
Default Need Help w/ 95 EX motor
Ok, here is the problem. Where the flywheel bolt to the motor(6 bolts part) is moving forward and backward just a little bit as you push and pull on it. Is it suppose to move at all? I s it the bearings? Please give some tips or sugggestions on how to fix this. Thanks.
Old Nov 8, 2002 | 10:59 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Need Help w/ 95 EX motor (cvcc)
crank is walking, thrust shims might be a little worn.
Did you use a Heavy Duty pressure plate?
keslerbuilt
Apr 16, 2014 03:59 AM
civicb16eg
Jan 6, 2007 11:26 PM
