car not reaching operating temp
hi guys,
i have a 95 civic lx 1.5 automatic
my temp sensor is either reading inaccurately or is not working at all, because it never reaches operating temp. it maybe reaches a quarter the way up. when i turn the car on it will idle at 1100 rpms, when i put it in gear it will idle at about 800 rpms. but once i start driving for a bit the idle is only at about 400 max. and the temp gauge will drop past the white line until i reach a red light when it will only go up slightly.
OK here's what I've replaced already
the coolant temp switch
the sending unit
the thermostat
i even replaced the coolant tank cos it was dirty and the cap had a crack
the relay switch for the fan too if that matters
even fuses
so i'm not sure if my car isn't getting hot enough or what? i know it cant be the gauge cos it wouldn't work at all right?
I don't know what else to try.any ideas would be great guys thank you
the sending unit
the thermostat
even fuses
ddb332
Dec 22, 2016 10:46 PM
Mr. Stiles
May 31, 2006 08:46 AM
confucius
Oct 23, 2002 02:46 PM
