Suspension & Brakes Theory, alignment, spring rates....
94+ integra trailing arm VS CRX trailing arm
Old Dec 2, 2016 | 05:53 AM
Canadian_EF's Avatar
Default 94+ integra trailing arm VS CRX trailing arm
Hi guys,
This has been bugging me for a bit. I have found various posts from people stating that the 94+ integra trailing arms and the CRX trailing arms are different. They are both options that guys will use to upgrade their drums to rear disks.
I finally measured the trailing arms. I can confirm that they are indeed slightly different.
I measured the offset of the lower bolt, that connects to the LCA. I used a square, and measured the flat, mating face of the wheel, to the lower bolt. The measurement is the exact same.
The upper bolt for the UCA is offset differently by about a half inch... I think this is where the different track width is coming from.
I've been searching for as much info on this as I can.
I don't understand: If the offset of the LCA bolt and the hub face is the same between the trailing arms, wouldn't the offsetup up top be made up for by using an adjustable upper control arm?
Old Dec 2, 2016 | 12:39 PM
spAdam's Avatar
Loved
Community Favorite
Default Re: 94+ integra trailing arm VS CRX trailing arm
Statically yes, but it changes the geometry/kinematics and therefore affects the handling of the car. Hard to say how. I'd be interested to see what the differences are.
Old Dec 2, 2016 | 03:09 PM
Tyson's Avatar
What different track width?
Old Dec 4, 2016 | 11:28 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
DA, DC, and SI trailing arms all have different track widths by about 2mm or so, it's barely worth mentioning.
Old Dec 4, 2016 | 12:59 PM
Tyson's Avatar
Yeah cuz it's different chassis....
brewerkz
Honda CR-V & Element
Jul 23, 2017 07:55 AM
shahriar35
Apr 21, 2016 03:19 PM
young geezer
Mar 10, 2008 04:20 PM
triggerstep
Suspension & Brakes
May 25, 2007 10:33 PM
Wes d
Jan 2, 2002 11:11 AM
