question about my integra
hi, im new to this forum and new to cars in general. i had a quick question about my 95 integra ls. so sometimes when i start the car up and go to put it into 1st geat it wont go all the way in. ive had to put it in second and take off that way several times. reverse is starting to do the same thing. any ideas on what might be wrong with it? thanks.
Start by replacing the transmission oil use some good quality MTF, if that does not work you may need to rebuild your tranny.
Also confirm clutch hydro system is good, fluid level up, bleed system and check both master and slave cylinders. 94
