Sohc zc swap in 91 civic si
Old Nov 27, 2016 | 04:27 AM
91tahitian.si's Avatar
Icon5 Sohc zc swap in 91 civic si
Wadup y'all new to the Honda scene with a couple of questions for you well conditioned enthusiasts. I plan on putting a Sohc zc motor & transmission in my 91 civic hatchback si . My questions are :
1- will I need to get 90-93 integra axles (since I will be using the zc transmission)
2-can I use my stock injectors
3-will I need injector ristor box
4-can I use my stock ecu
5-what's a good clutch for the Sohc zc transmission
Old Nov 28, 2016 | 05:43 PM
Tyson's Avatar
Default Re: Sohc zc swap in 91 civic si
it will be a straight swap. everything stock.
the tranny more than likely is the same too. take a look and describe the label, if its gold or white and what it says.
what makes you think all these things would be different?
Old Nov 29, 2016 | 02:17 AM
Mostly wondering about the axles . I've heard people say there using 90-93 integra axles with the Sohc zc transmission.
Old Nov 29, 2016 | 05:31 AM
Tyson's Avatar
Sohc zcs came in a lot of different flavors in many different cars. The big axle sohc zc trannies are possible but rare. don't count on it unless you know specifically what you're looking for.
Just see what you get and describe it. Or just measure it yourself and see if your old axle fits in.
Old Nov 29, 2016 | 09:12 AM
v4lu3s's Avatar
RTFM
if you are getting the engine and transmission attached to one another the half shaft bolted to the block is a dead giveaway that you need the teg axles.
Old Nov 30, 2016 | 07:02 AM
If I use my Si transmission will it fit the Sohc zc with no modifications ? & if so then I can use my stock axles correct ?
Old Nov 30, 2016 | 09:11 AM
Tyson's Avatar
Of course.
xparalandrax
Nov 7, 2007 07:08 PM
2kTeg
May 3, 2005 01:34 PM
shoeboxbeater
Oct 14, 2004 07:57 AM
zeptozorro
Jan 18, 2004 09:01 PM
smithbling
Nov 2, 2002 09:17 PM
