LS crank in GS-R Question about girdle
Old Nov 26, 2016 | 08:57 PM
93eh2b18c1's Avatar
Default LS crank in GS-R Question about girdle
I've searched, I cannot seem to find any straight forward answer's about this. I have a gs-r block and I'm using an LS crank. My question is can the gs-r girdle be used? Or does it need to be modified? Is there a company that makes one that's note worthy? Thanks!
Old Nov 27, 2016 | 04:48 PM
chrisc543's Avatar
Default Re: LS crank in GS-R Question about girdle
Yes it will work without modification. Need to measure for proper bearings though. Also will need to block off the gsr oil squiters and use ls rods and pistons.
Old Nov 27, 2016 | 05:25 PM
93eh2b18c1's Avatar
Awesome thank you. I have the GE oil blocks, Eagle LS rods and the B18a/b king bearings. That should be everything I need right?
Old Nov 27, 2016 | 05:47 PM
chrisc543's Avatar
I think the bearings should be for gsr.
Old Nov 27, 2016 | 08:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Main bearings are the same size... check fitment and change as necessary. The rod bearings will have to be changed because LS rod bearings are wider than the GSR rod bearings.
Old Nov 27, 2016 | 08:41 PM
93eh2b18c1's Avatar
Gotcha. I have the ls rod bearings is what I meant to say. Also the thrust washers. So I should be good to go?
Old Nov 27, 2016 | 08:48 PM
SIR-G Amp's Avatar
In theory, yes. But it would be best to plastigauge your bearing clearances to find out exactly what size you need.
-Amp
Old Nov 27, 2016 | 08:57 PM
93eh2b18c1's Avatar
-Amp
Yes we will do that. This is my first build I have lots to learn. My friend is helping me he knows worlds more than I do. I just want to make sure I have all the right parts come game day.
I had to put the mfactory lsd on hold this weekend because I forgot to order the diff bearings.. I'd hate to get to putting my motor together on his time off to be held up for having the wrong parts.
I appreciate all the advice and replies!
Hellahflush
Jan 28, 2015 07:20 AM
absoluteacura
Jul 31, 2008 08:08 PM
dc4teg95
Apr 7, 2008 10:40 AM
boostd ls
Mar 6, 2008 02:02 PM
akura404
15
Apr 1, 2006 06:57 PM
