92-95 eg rack and pinion non power swaps
Old Nov 25, 2016 | 05:13 AM
Joshiata's Avatar
Default 92-95 eg rack and pinion non power swaps
morning everyone! Hope everyone here had an excellent thanksgiving. I know I did. As a matter of fact I had such a good time I broke my Jeep and it leaves me to daily my hatch till I sort out the issue lol two of my biggest concern are the steering me no heat lol I have a good mount of play in my steering and I figure it needs to be replaced. I hear the only swaps are from non power to power dc2 and I don't want to go through the hassle of installing power steering lines and all that. I've heard from local guys here that the sealed Ef racks work wonders but I'm just not convinced. I'm trying to shorten the ratios on the steering while I'm going through the process of replacing it but with which rack is my question? Any suggestions?
Old Nov 25, 2016 | 07:22 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Default Re: 92-95 eg rack and pinion non power swaps
You can replace just the rack and pinion with a Quaife kit.
eH.
Old Nov 25, 2016 | 08:27 AM
White_EG1's Avatar
Or you could use a powered 94-01 integra rack they have a even quicker steering ratio. All you need to do is the loop the power lines, and you'll need a integra U joint, and D bracket.
Old Nov 25, 2016 | 08:33 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
The play in your rack might just need an adjustment. This won't help speed up your rack but it might be the easiest fix for your loose rack. A replacement might not be necessary accept for your desire to speed up the rack.
Old Nov 26, 2016 | 03:33 AM
Joshiata's Avatar
im still considering this but it all comes down to how much flow I'll have after the holidays lol it will work with a d series engine no?
Old Nov 26, 2016 | 03:35 AM
Joshiata's Avatar
Attachment 426034
couldnt hurt to get an alignment before I start buying ****. I'm gonna upgrade it nonetheless but I don't really need too just yet I guess lol thanks for the response
Old Nov 26, 2016 | 03:38 AM
Joshiata's Avatar
eH.
I will definitely check this out. If it turns out to not need replacing I'll probably pick this up and leave it non power. Thanks for the reply! Much appreciated
Old Nov 26, 2016 | 05:17 AM
94EG8's Avatar
Seagull Management
Just as an FYI the power steering lines are so simple on those cars it's really not a big deal to add them in. You will need to swap the subframe though.
Old Nov 26, 2016 | 09:58 PM
White_EG1's Avatar
Lol of course the steering rack has nothing to do with your engine. Get one from a junkyard they're pretty cheap.
SC_HOBD_1816
12
Feb 5, 2009 05:49 PM
ridethebull
Jun 27, 2006 03:21 PM
2DoorBandit
Oct 25, 2005 01:40 PM
underrated99si
40
Aug 5, 2004 11:17 AM
