after hours of reading thru the search still wonder can you use DX distro for MPFI?
Old Nov 8, 2002 | 06:01 PM
89 CRX SI's Avatar
Default after hours of reading thru the search still wonder can you use DX distro for MPFI?
as title staes
Old Nov 8, 2002 | 06:15 PM
USDM 4G VTEC's Avatar
Default Re: after hours of reading thru the search still wonder can you use DX distro for MPFI? (89 CRX SI)
no
the DX has a plug with 5 cables and another one with 2
the SI one has one plug with 7 and another with 2
in other words, the DX doesnt have a sensor the Si do.,..
Old Nov 8, 2002 | 08:11 PM
the DR.'s Avatar
Default Re: after hours of reading thru the search still wonder can you use DX distro for MPFI? (JDM EF9)
the dx distributor doesnt have the crank sensor inside, because DPFI dont need to time the injectors to engine timing
Old Nov 8, 2002 | 10:05 PM
89 CRX SI's Avatar
Default Re: after hours of reading thru the search still wonder can you use DX distro for MPFI? (CIVICtypeS)
ok thx it was just my inderstanding that all you needed was the si plug.
WE have now got an Si one anyhow.
There is also one yellow wire coming out of the main harness went to one of the DPFI injectors. do i just leave it not connected to anything.
and there is one black wire with yellow strip from EACV do i just splice this into the main harnesse black wire with ellow stripe?
THX
sk8erracerguy
21
Oct 14, 2005 09:36 PM
e jay one
Aug 13, 2005 08:34 AM
fwpguy
Oct 8, 2003 06:17 PM
turbohf
13
Feb 20, 2003 04:38 PM
Agent Daimon
Dec 17, 2002 03:42 AM
