Will ek ex sunroof mount in ek hatch
Sorry if it's already been posted. Would like to know if anyone has mounted a sunroof from an ek coupe into an ek hatch. I'm the second owner of my ek hatch an the original owner mounted an aftermarket sunroof. I want to go with an oem look an function. Any input would be helpful thank you for your time.
You'll need the roof skin from an EX/Si coupe along with the sunroof assembly, then you'll need remove most of the original hatch roof skin, you'll need the rear section though as the coupe roof is shorter. You may also need some of the braces that go under the roof skin. You're also going to need a headliner, my best guess is to again splice both headliners together and have an upholstery shop cover the finished product with fabric.
Wow was not thinking it would be all that. I already have an aftermarket sunroof and was hoping I could just swap. Thank you for your input though. Appreciate it.
