2000 Accord Coupe V6 sometimes doesn't start unless i hold the gas pedal for a min
Old Nov 20, 2016 | 07:58 PM
hondroids's Avatar
Default 2000 Accord Coupe V6 sometimes doesn't start unless i hold the gas pedal for a min
It doesn't happen all the time but i use my car to get into work and dont want to stall on the highway. I once kept on stalling while driving when the gas was on low but not all the way empty. I do hear the fuel pump make a noise when i put the ignition on ON (II) so im not sure if its that. I am getting misfire codes. Thanks!
Old Nov 24, 2016 | 03:46 AM
poorman212's Avatar
Default Re: 2000 Accord Coupe V6 sometimes doesn't start unless i hold the gas pedal for a mi
Not much information to go on here?
Could we start with a bit more info...... what "seem" to be the conditions when this happens, do the codes only show up when the starting issue happens......
Old Nov 24, 2016 | 06:50 AM
hondroids's Avatar
It's a v6 and the code came up one of the times this happened. It happens randomly. Lately at almost every startup I need to give it alot gas for it to go a speed that I would otherwise reach easily without pushing down the pedal as much. Thanks
Old Nov 26, 2016 | 02:49 AM
poorman212's Avatar
Ok, some thins happens when the car is cold as well.....that helps narrow things down a bit. What is the "health" of the tune up items, mainly the plugs since the is a COP set up?
Are there any other stored or pending codes besides the miss fire (p030X, p1399)
bluelamb
Mar 26, 2016 02:46 AM
avargas28
Apr 10, 2014 07:42 PM
porter1929
Jun 23, 2012 06:26 AM
devilpuppy
Dec 21, 2007 11:01 PM
phil5807
Apr 5, 2005 04:40 AM
