NY 1985 Bmw 325 Restored Euro/Hartge/Recaro/Houndstooth/Rust Free E30
Old Nov 20, 2016 | 07:34 PM
PR3LUDE's Avatar
Default 1985 Bmw 325 Restored Euro/Hartge/Recaro/Houndstooth/Rust Free E30
Hey what's up Honda-tech. I have for sale my extremely clean 1985 Bmw 325 5 speed. It is a rust free southern car that has been given the euro treatment. Undercarriage is mint. One of the cleanest e30's I have owned. It runs and drives extremely well. I drove the car 10 hrs straight from North Carolina without any issues. The car has had a ton of maintenance done. Mileage is 182k. I'm looking to get $7000. Clean title in hand. Please give me a call if you have any questions (347)44O-9257. Thanks. Below is a list of maintenance done within the past 18 months. All parts are Oem Bmw or German made parts. I have a clean set of Super eta pistons, freshly machined rods and bearings as well as a Zender m3 evo spoiler with adjustable gurney flap for non m3 e30's that can be added to the deal
Engine:
Timing belt
Water pump
Spark plugs & plug Wires
Distributor & Rotor
Front seal
Valve cover gasket
Valve adjustment
Shell rotella oil w/Mobil one filter
New Fan clutch (Included)
Brand New Gas tank
Suspension:
Bilstein sport struts/Shocks
Ireland engineering springs
Control arms & control arm Bushings
Front sway bar end links
Front Upper strut mounts
Rear subframe bushings
Inner and outer tie rods
Drivetrain:
Redline MTL gear oil
Clutch
Pressure plate
Throw out bearing
Pilot bearing
Driveshaft including center support bearing and Guibo
Passenger side cv axle
Brakes/Hydraulics:
Rotors & pads front & rear
All 6 brake hoses
Brake master cylinder
Brake Booster
Clutch master cylinder
Slave cylinder
Exterior:
Complete window out respray in original Burgundrot metallic using Ppg paints($4k for the paint job)
Windshield seals front & rear
Chrome locking strips
Various trim clips
Chrome trim deanodized and polished
Euro bumpers front & rear
Euro grills
Smoked Hella crosshair projector style headlights w/
5k Hid kit
Smoked taillights
Bmw roundel front & rear
Thule roof rack(Not included)
Interior:
Recaro Ls seats
Wedge engineering brackets
Houndstooth rear seats w/headrest
Houndstooth door panels front & rear
Anthracite carpet
Zhp shift ****
1m floor mats
Momo prototipo steering wheel
Momo hub adapter
Clean dash
Performance:
IE3 sport springs (Ireland engineering)
I-spec twin pipe headers
Cat delete
Ansa twin pipe sport exhaust
Sssquid 93 octane eta chip
3.25 lsd from a 535is
15x7 Hartge wheels et25(Made in Japan)
Dunlop dz102 205-50-15
Issues:
Being a 31 yr old car it has a few minor issues. Passenger window regulator needs attention, window works fine but clicks when all the way up. Headliner needs to be redone. Leaks oil from the front seal. Shifter bushings have play (New rebuild kit included)
Speedometer works intermittently. Blower motor squeaks (Replacement included). Central locking issue
(Trunk actuator and lock tumbler/cylinder rebuild included)
Old Nov 20, 2016 | 08:00 PM
PR3LUDE's Avatar
Default Re: 1985 Bmw 325 Restored Euro/Hartge/Recaro/Houndstooth/Rust Free E30
Pics of the car in the paint booth...
Old Nov 22, 2016 | 03:07 PM
PR3LUDE's Avatar
A few pics in the sunlight...
maximusmda
Aug 29, 2009 02:33 AM
SneezinCD5
Jul 17, 2009 04:43 PM
Styler93GSX
Oct 2, 2006 10:31 AM
Behan
Jul 8, 2003 02:09 PM
