Civic hood sticky substance..
I would try a little nail polish remover (acetone base) on a small part to see if it softens it. If it does than paint thinner (acetone) will take it right off.
The detailers method is a clay bar but that is a long and slow process.
Mineral spirits will soften and remove paint way sooner than acetone.
Detailers use acetone to remove tar and road grime all the time. You don't let it soak in long enough to soften the clear coat and it melts tar and sap right off.
Right after, you wash the car to remove all contaminates, including the acetone.
Last edited by TomCat39; Nov 20, 2016 at 04:15 PM. Reason: Wow, adding words in the wrong spots. fixed.
If you do decide to try the acetone (I would try WD-40 first though), be sure to not let it sit on the paint. I would try just a small spot with a rag to see if it melts the goo and wash immediately.
If it doesn't melt the goo right away, then it's not recommended for removal as the length of time to affect the goo will likely be long enough to also affect the paint.
Actually digging into this..... It appears, the reason acetone is gotten away with at detail shops in the prep bay is they then turn around and cut and polish the paint. So any hazing of the clear coat is removed by the cut and polish.
Please ignore my suggestion of using acetone as a goo remover unless you plan on cut and polishing what you use it on.
I didn't realize the reason why the detail shop I worked at always used it was they always were cut and polishing the car and solvent is faster than a clay bar for tar and sap removal. Also, it wasn't used on a dry vehicle, it was sprayed on the sides after the car was whetted down.
