Hi everybody, I've got this 92 wagon pretty much gutted, but plan on using it as a storage shed until scrap goes up again, so I haven't pulled any of the glass and lots of engine parts still there. Please let me know if there is something you can use that I haven't listed.
Get some good deals on parts before I put them on ebay, I would rather sell them here and leave greEdbay's cut out of it anyways! I can box up any combination of parts you would like, only charge actual shipping +paypal fees. Local pickup encouraged, but nobody lives in Wisco anyways.
Don't be shy, I would rather sell these parts than keep them!
Part list:
Rear Wagon Hatch Door inside trim:
$50
Please notice the small rectangle plastic cover has a crack that will need to be epoxied, and most of the studs attaching the upper cover to the lower cover have come apart. A few of the studs are in the bag if someone wanted to attempt a partial repair.
Inside rear trim set:
$100 for everything
If nobody wants the whole set I can sell individual pieces. Please look at the pictures to see some studs that have snapped off and scuffs. Overall the pieces pictured are in good shape
Door panels:
$20 a piece
interior door handle included with each one
Front above door trim and seatbelts:
$20 a piece
Please notice the crack in the drivers side trim, above the B pillar. same price if all you want is the seatbelts but shipping will be way less cause I will break off the trim. Please notice the drivers seatbelt attaching bolt has a rusted solid bracket
Interior Parts:
Sunvisors - $20 for the pair
Cruise/sunroof switch light dimmer - $5 each
Dash clock - $5
Dash trim - $30
Glove box door - $20
Turn signal/headlight/wiper switch levers - $15
Dome light - $5
Rear center brake light - $15
Heater Controls - $25
Steering column trim - $15 for both
Steering wheel includes trim and cruise buttons - $35
Airbag harness - $15
Airbag - $30
Owners manual - $5
Instrument cluster - $50
Automatic gearshift assembly - $40
Gearshift trim - $10
E brake lever - $15
Taillights:
$20 each
Please notice the inner ones are in worse shape than the outer ones. The left inner has one crack across the lens and some cracks on the rear, one of the attaching studs is broke off but included. The right inner has stripped screw holes to attach the bulbs
Headlight assemblies - $50 each
Please note the left turn signal light has a small chip and crack in the plastic lens
Grill center - $30
Some wear on two of the attaching holes and one stud broke
Fuse panels - $15 each
Intake manifold complete w injectors, throttle body, IAC valve, etc - $150
Blower - $20
Rear seat belts set - $25
