Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Stuck Tensioner Bolt on a 06' Civic.
Old Nov 16, 2016 | 12:08 PM
KaiJonesy's Avatar
Default Stuck Tensioner Bolt on a 06' Civic.
Hey guys,
looking for some assistance or opinions on what the hell I need to do to get this pin out. At first I used a 8mm hex socket and immediately stripped it. Spent a few hours afterward pounding a torque bit into it to create new threads in hopes to bite and stripped that too. Purchased an extractor kit to pound into the thing and as you might guess, broke one off in the POS. So, had a mutual friend come over with a Mig welder and he tried to weld a Torque bit in and failed. For the last 3 hours I've been trying to drill the weld out and maybe create a new hole for an extractor or just drill the head of the bolt off entirely to remove the tensioner bracket. This was supposed to be a water pump replacement and I've been on it for 3 f*****g days!
Old Nov 17, 2016 | 08:50 AM
foumer's Avatar
W95 gives me a hard-on
Default Re: Stuck Tensioner Bolt on a 06' Civic.
Originally Posted by KaiJonesy
Hey guys,
I feel you pan bro. The tensioner on mine was busted, so I bought a whole kit with the bracket. I couldnt get the bolt out so I was lucky enough to just be able to replace the pulley and tensioner. I would try to weld a hex head from a screw to it. Try to lower the engine a bit so you can access to the bolt by the wheel well if you havent done that already. Hit it with an impact wrench as to tightening and then reversing it.
B20Zer
Jan 10, 2018 07:11 AM
bujeezus
16
Apr 18, 2012 08:57 AM
PAPA TED
Jul 27, 2004 01:44 PM
Btothe3rdDegree
May 15, 2003 10:32 PM
shermanyang
Jul 29, 2002 08:38 AM
