D16Z5 dizzy
Hello,
I have a D16Z5 CRX which has some weird missfire problem. I have already checked all main components, all seems to work fine. However, cap on the distributor seems to not fit perfectly, because holding points are drilled and only ghetto style bolts holds the cap. So I am thinking about changing distributor body. The worst thing is that I can't find any D16Z5's for parts.
Sooo... My next thought was - what dizzy would work on D16Z5 from other engines? Could somebody do a little list of engines that has similar, maybe correct dizzy, that would work like stock one?
the only distributors that will fit the D16Z5 are:
D16A1 (88 & 89 only)
D16A8
D16A9
JDM DOHC ZC
Just so you know, the spark plug wire locations on the distributor cap on the DOHC D16 engines are not in the same location as they are on the SOHC engines - Number 1 is at the top
D16A8
D16A9
JDM DOHC ZC
JT2MA71
Apr 5, 2007 10:50 PM
JustAnotherRex
Nov 20, 2006 07:23 PM
99sibluehatchwitb16
11
Jan 25, 2006 06:49 PM
I'll try to find one of these.
