NM 1990 Si hatch Black DOHC ZC +awd kit.
Old Nov 14, 2016 | 04:55 PM
Slver87si's Avatar
Default 1990 Si hatch Black DOHC ZC +awd kit.
1990 Honda Civic Si with DOHC ZC swap and rear disk
conversion $4500.00 Firm. Cash in had offers alwaysconsidered.
Name and phone number. Wes Olson 614-402- 6680. please text or email me wesley.m.olson@gmail.com
List of parts I have in storage Includes:
AWD swap kit from an 88 civic wagovan (installation required)
Transmission
Reground flywheel
Clutch disk
Shifter linkage
Rear differential
Rear trailing arms
Rear lower control arms
Various mounts and all 4 drive shafts + intermediate shaft.
Spare DOHC ZC head. (needs re-assembled and/or rebuilt-your choice)
Several boxes of junkyard find spare parts are included with this car.
Includes spare exhaust header for DOHC ZC
Spare steering shaft and two steering wheels.
Misc throttle body parts and emissions controls/ vacuum lines
I have some spare seat covers that are in better shape than the ones installed.
Work that I have done and parts that I have replaced. All oem or factory parts when possible.
All suspension bushings replaced
New KYB shocks with adjustable firmness.
New brake system.
Master and booster cylinder
New brake lines. Front lines are steel braded
New calipers pads and rotors.
Rear disk swap. all new parts.
New parking brake cable RH(still needs one on the left)
New battery as of June 2016
New tires
New fuel filter.
New fuel injectors
New spark plugs
New cap and rotor
New upper a arms – on left side as of June 2016 plus the wheel bearing. (RH side ball joint has failed)
New sway bar bushings and end links
New clutch cable
New throttle cable
Shifter linkage and bushings/seals all replaced
Shifter shortened
New steering rack
New alternator from Integra.
New belt and tensioner.
Everything works including the sun roof. The car is reliable. It runs good and it runs strong. Over
the years that I have owned this car I have gone out of my way to keep it as original as possible. It gets
good mas mileage too 33~mpg.
This car is available any time if you have cash in hand. Right now I'm on the road for work and wont be home for a few weeks. Feel free to text me 614-402-6680. You'll need a truck or suv for all the parts I have saved up. The transmission and spare cylinder head are in crates. everything else is in plastic bins.
*****Recent update******. Wife said looks like someones dog chewed on a fender. I have not seen the damage and don't know how bad it is. I'll get a pic of the damage as soon as I can.
7rrivera7
Mar 1, 2004 06:49 PM
90CRXracer
Dec 23, 2003 02:27 PM
91hatchnewb
May 12, 2003 10:55 PM
