Is it possible to switch from 97 Accord SI-R ECU to Euro R ECU?
Old Nov 13, 2016 | 10:26 AM
Blake Harvey's Avatar
Default Is it possible to switch from 97 Accord SI-R ECU to Euro R ECU?
I have an Accord with a JDM H22A out of a 97 Accord SiR and I'm just curious if I could change the ECU and use an ECU from a 97 Accord Euro R since it is essentially the same engine
Old Nov 13, 2016 | 12:32 PM
GhostAccord's Avatar
Default re: Is it possible to switch from 97 Accord SI-R ECU to Euro R ECU?
What is your current setup, Year, Model of car and what year model ECU?
From what I have read using a stock Euro R ECU is a lot easier said than done. If you need to stay OBD2 it would probably be cheaper to see if you can find a 96 P13 ECU. They are not the easiest to find, but they are the only OBD2 H22 ECU that doesn't have an immobilizer.
Other than that it would be converting to a tuneable OBD1 ECU and getting it chipped & tuned.
Old Nov 13, 2016 | 07:18 PM
97hb's Avatar
As long as it plugs then it might start. Might have to cross some wires up.
Old Nov 15, 2016 | 01:11 AM
The car is a 1996 Accord LX and the engine, tranny, and ECU is from a 1997 Accord SiR. Also, the car is already converted to obd 1. It's pretty much stock other than a Megan Racing exhaust system and CAI.
Strelspeed
May 28, 2012 02:09 PM
hatchdrvr
Apr 28, 2011 02:50 AM
Reno CD-6
Oct 6, 2009 02:01 AM
gaydm.accord
Jun 27, 2009 12:09 PM
