07 Si EPS issue
When I got my car in the begining of summer. About 2 weeks in of owning it. I come to start it one cold mowning. I notice the eps light is on. Since then it's done it once in a while in hot weather. I usually wait 5 sec before starting the car. If the light winter turn off, then I turn the car off and turn the key on & off 7 times. then start it. now that it's getting cold it's happening more often & my key trick wont work. if I can't get the eps to turn on, I just drive for a few miles then try the key trick at a stop. I've done research about this but no resolution . where exactly do I check for issues? thx in advance!
Depending on your VIN and mileage, there was a warranty extension for Electric Power Steering With DTC 32-09 or 61-04, where the EPS control unit may get replaced.
2006–09 Civic Si 2-door Check the iN VIN status for eligibility
2007–09 Civic Si 4-door Check the iN VIN status for eligibility
Go to a parts store like Autozone and see if there are the stored trouble codes 32-09 or 61-04.
If there are, then contact a Honda dealer regarding whether your car's qualifies under the extended warranty, or call Honda America.
check for the code once the eps light is on?
Steftravels
20
May 25, 2012 12:25 AM
Meesheltx
Honda Civic (2006 - 2015)
Nov 14, 2011 07:07 AM
BOOSTEDgreeneg
Sep 6, 2005 10:06 AM
