1990 Honda accord electrical issues
Old Nov 11, 2016 | 04:19 AM
Ryan Rutledge's Avatar
Default 1990 a/c heating issues
So I replaced the blower motor and when I put it back in, there is this gap where air escapes
Previous owner tried to hide this with tape and I found it, how would I go about fixing this?
Old Nov 11, 2016 | 09:24 PM
holmesnmanny's Avatar
Default Re: 1990 Honda accord electrical issues
Disconnect the big wire attaching to the alternator and making sure it's not touching ground in any way try to jump start it again. If it tries to start without blowing the fuse then the alternator is now blown.
Old Nov 14, 2016 | 12:41 PM
So I replaced the alternator and now there is this squeal from the belt that gets louder and louder when I start the car
Old Nov 14, 2016 | 07:10 PM
MAD_MIKE's Avatar
MM Gruppe B
The belt is either worn, loose, or has oil/grease on it.
Verify it is tight enough, do not overtighten.
Verify there is no oil/grease on the belt, use some WD-40 on the belt to help remove the oil.
Old Nov 15, 2016 | 10:34 AM
Ya I forgot to put the tensioner bolt back on the bottom of the alternator so I had to redo the whole process and now it doesn't squeak anymore.
Thank you both of you guys for helping me with my problems, i'm just starting to learn mechanics so im working on my car over time. Its cheaper then going to a mechanic.
tommyoc
Jul 19, 2006 07:09 AM
2SlowDC
Jun 4, 2006 12:10 PM
speedtrash
Jan 16, 2006 07:06 PM
patastinky
Mar 23, 2004 07:32 AM
