Auto Transmission maintenance
Old Nov 10, 2016 | 08:49 AM
smithers646's Avatar
Default Auto Transmission maintenance
Hello all. 1994 Accord LX, F22B2 engine with Automatic Trans. 128K miles.
We bought the car used about six months ago, and (long story short) the cascading issues have led to a complete engine overhaul.
Right now the engine block is at the machine shop for ~4 weeks, and the transmission is sitting on the floor.
QUESTION: Are there any transmission maintenance/checks I should be doing now, while everything is very accessible, prior to install?
There were a number of things on the engine side that indicate the car was not well maintained. Upon draining, the trans fluid was extremely dark, and there were a few solid metallic flakes and some 'dust-like' particles settled in the bottom when I poured out the white drain bucket. The magnet on the drain plug was pretty fuzzy.
FWIW, when it was driving, the transmission exhibited NO shifting or slipping issues.
Thanks for any advice or suggestions!
Old Nov 10, 2016 | 09:20 AM
holmesnmanny's Avatar
Default Re: Auto Transmission maintenance
Buy two 1 gallon jugs from Walmart. Pour all the old fluid in one jug. Put them on level surface. Pour new Honda atf fluid in other jug to the same level.
Old Nov 10, 2016 | 09:54 AM
Thanks, Holmes. Measuring the volume that came out is not an option- the trans system got drained in increments. Some came out when I pulled the radiator, some more came out when I pulled the AT drain plug, and then some more came out when I rigged the engine+AT out. I really don't know how much came out altogether, and at any rate, it's all in the recycle/slops jug now!
One think to add- I am figuring on flushing the AT cooler and lines to the radiator, but I'm not settled on a flushing fluid yet...
bren611
May 16, 2014 09:58 AM
hlinar
Nov 19, 2012 05:54 PM
1996accordlx22
Aug 5, 2012 07:30 AM
lovedam
Sep 9, 2011 04:21 PM
ferio252
Oct 28, 2007 04:40 PM
