Bogs, hesitates during acceleration
Okay so I have a 97 accord VTEC car starts up fine I drive around the corner or let it warm up and the car will start to bog and shake like if it wants to die but it doesn't I step on the gas and it don't go anywhere it will only very slowly rev up I pulled out my scanner and its saying 02 sensor bank 1 and bank 2 I changed the distributor fuel filter plug wires spark plugs and still have no idea
Here is what i found
Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit poor electrical connection
- Faulty Engine Control Module (ECM)
The code means that there is a problem with the heater element circuit of the heated oxygen sensor. The control module monitors how long it take the sensor to warm up and start sending an adequate signal. The code is triggered when the sensor is taking too long to warm up. Water getting inside the heated oxygen sensor connector can caused the heated oxygen sensor fuse to blow. Before replacing the sensor, check for the condition of the heated oxygen sensor fuse and connectors. If the sensor and connector are OK, replacing the O2 Sensor 1 usually takes care of the problem
Here is the link to this just copy and pasted so its all right here: P0141 HONDA O2 Bank 1 Sensor 2 Heater Circuit Malfunction Bank
Remove the S1 sensor, see if the engine can more freely rev. Next remove the catalyst to check it for damage.
951parts
Aug 9, 2012 11:43 AM
jpangeles
Sep 12, 2004 05:23 PM
