CTR Pisons in GSR block
Old Nov 8, 2002 | 04:01 PM
AllTDMnotJDM's Avatar
Default CTR Pisons in GSR block
Does Anybody know the compression if I install CTR Piston in a GSR block with a ITR head? Do u think the compression will be above 12.1
Old Nov 8, 2002 | 04:04 PM
hybridreams's Avatar
Default Re: CTR Pisons in GSR block (AllTDMnotJDM)
should be a tiny bit lower with that ITR head.
Old Nov 8, 2002 | 04:10 PM
CherryRacing's Avatar
With a 3 layer head gasket its exactly 12:1
thats my exact setup
Old Nov 8, 2002 | 04:20 PM
bokguay's Avatar
yes it will...im running about 12:6 cr right now
Old Nov 8, 2002 | 05:22 PM
ahcjar103's Avatar
Default Re: CTR Pisons in GSR block (C5_ALLMOTOR)
that's my setup. good stuff.
Old Nov 8, 2002 | 07:12 PM
Chugger's Avatar
Default Re: CTR Pisons in GSR block (ahcjar103)
i wanna put ctr pistons in my gsr i am running a gsr head as well i am scared of detonating during the hot summers is this possible on pump gas i think it will be like 12.6 not sure race gas is expensive these days any opinions
Old Nov 10, 2002 | 02:39 PM
kidkombo's Avatar
Default Re: CTR Pisons in GSR block (Chugger)
i heard from a bunch of people that tuning is key to having an extremely high compression on pump gas. let me kno if im wrong...
Old Nov 10, 2002 | 02:42 PM
HybridHatchC1's Avatar
Default Re: CTR Pisons in GSR block (kidkombo)
i was also looking into throwing in some ctr pistons with ctr cams, along with my skunk2 intakemanifold, and ecu, would this setup with ctr pistons just bolt right in or do you need boring or anyother work done?
Old Nov 10, 2002 | 02:44 PM
prospeed's Avatar
Default Re: CTR Pisons in GSR block (Civ-JDM)
the ctr pistons should drop right in if you want to stay with the standard bore. I recommend going .25 over on the bore. with the .25 over Civic-R piston.
Old Nov 10, 2002 | 03:13 PM
Default Re: CTR Pisons in GSR block (prospeed)
so i would have to rip everything apart and send it away to get bored .25 over, then would it still work with the stock head with ctr cams?
Old Nov 10, 2002 | 03:32 PM
prospeed's Avatar
yes it will work just fine
Old Nov 10, 2002 | 04:14 PM
fukaintmuven's Avatar
im runnin an ls/ b16 head wit CTRs but my cr is too too high... im pingin like crazy... almost 13.1
Old Nov 13, 2002 | 09:52 PM
Vanilla4215's Avatar
Default Re: CTR Pisons in GSR block (fukaintmuven)
Here Robert http://www.bojangs.com/calculator/ Have fun.
knuckk
Dec 19, 2007 06:07 AM
SexyHatchie
Sep 24, 2007 12:13 PM
ALLMOTOR CRX
18
Jun 22, 2007 01:39 AM
MRCHUNDOESAY
Dec 2, 2005 09:52 PM
jeremy.
199
Dec 23, 2004 03:45 PM
