1994 honda accord vtec
Old Nov 4, 2016 | 04:16 PM
Dylan Austin's Avatar
Default 1994 honda accord vtec
So I just bought a 1994 honda accord 2.2L Vtec and i was looking at my engine and everything else the other day and I noticed there is a loose part laying around by the distributor. I have no idea what it is and why it is loose please help me find out what it is . Thank you
Old Nov 7, 2016 | 10:10 PM
Mr._BB6's Avatar
Default Re: 1994 honda accord vtec
That's the ignition coil. It's held on by a bracket with 4 12mm bolts.
Old Nov 10, 2016 | 06:05 PM
ROTARD's Avatar
Not sure if this is always the case but...
Vtec engines come with a coil built into the distributor, non vtec have an external coil that bolts where the vtec solenoid would go. It looks like this car had a vtec swap done.
You will probably need to make a custom bracket to hold it, I havent found one to buy yet. If anyone knows of one, let us know.
Old Nov 14, 2016 | 07:30 PM
MAD_MIKE's Avatar
MM Gruppe B
If the car is not an EX model then the VTEC engine was swapped in. EX VTEC(F22B1) uses an internal coil Hitachi distributor.
If it is an EX model then someone did some goofing and put quite a bit of work into using the non VTEC(F22B2) TEC distributor.
I see that the front water outlet appears to have RTV squished out, it uses a triangular shaped 'O' ring, not goo.
And there appears to be a loose black wire with a female spade connector dangling.
B2 external coil normally bolts to the head behind the distributor, but with the VTEC engine it cannot as the VTEC solenoid now occupies that space.
94jdm
Jun 26, 2016 12:32 PM
aust 97 coupe
Jan 14, 2009 04:00 AM
preludeboybmw
Dec 10, 2007 09:50 AM
eg:R
Jul 5, 2007 06:14 PM
souljah07
May 31, 2007 07:27 AM
