Anyone with coilover install experience on preludes?
Old Nov 4, 2016 | 01:26 PM
andrwgs's Avatar
Default Anyone with coilover install experience on preludes?
Wondering if these will bolt right up? What other parts will i need from old suspension? They are model GSH92-1USS2 and were given to me by a mechanic friend
Old Nov 4, 2016 | 04:06 PM
Prudz_lude's Avatar
Default Re: Anyone with coilover install experience on preludes?
Yes, I had those will bolt right up and are a great coilover. The only issue you'll have is the brake lines don't have anywhere to attach to. I custom made some brackets. Very easy to do. Buy some metal strips (mine had pre drilled holes) then slap a bolt and nut on it and then you won't have loose brake lines. Don't zip tie them, that is asking for trouble.
Old Nov 5, 2016 | 01:28 AM
andrwgs's Avatar
Thank you very much i am glad to hear they are a good coil, and I did not think of the brake lines despite installing some bilsteins on my e36 the other day xD (which did have a place for lines)
Old Nov 5, 2016 | 02:53 AM
SnlpeR's Avatar
youre gonna need the top hats from the original suspension
and youre gonna need a spring compressor to get those top hats removed from the original suspension
Old Nov 9, 2016 | 10:36 AM
thusee's Avatar
Also the front forks off the old suspension.
Mishako129
Jun 10, 2012 10:03 AM
jdmspoonitr
Jan 5, 2011 04:02 PM
LBBP R
Honda S2000
Jul 30, 2005 06:13 PM
RSVTECDC4
Jul 19, 2004 04:58 AM
ej one
May 21, 2004 07:08 AM
