1991 honda ef sedan clutch cable adjustment
Old Nov 2, 2016 | 09:23 PM
jdm91ef's Avatar
Default 1991 honda ef sedan clutch cable adjustment
Does anyone know how to adjust the clutch cable, i have a problem i cant put it in gear only when the engine is not running. So i think it needs an adjustment on the clutch cable.Has anyone had a problem, like this.
Old Nov 3, 2016 | 06:39 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: 1991 honda ef sedan clutch cable adjustment
There's a **** on the cable itself where it attaches to the transmission [bracket]. Turn the **** to tighten, you'll see the clutch lever move upward.
Old Nov 3, 2016 | 10:59 PM
jdm91ef's Avatar
How much do i need to turn it, does it suppose to be really tight?
Old Nov 6, 2016 | 03:27 PM
24TEN's Avatar
PHANTOM MENACE
It's going to "feel" tight no matter how someone explains it with words. You can turn it a few turns at a time and try shifting with the engine running until it works.
Old Nov 7, 2016 | 05:40 AM
jlicrx's Avatar
Old Nov 7, 2016 | 09:34 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Grab the release arm sticking out of the transmission and move it up and down. There should be some play, I like about 1/4"
Old Nov 8, 2016 | 10:13 AM
jdm91ef's Avatar
I adjusted it already and I still can put it in gear when the engine is running. So I don't thing that's the problem, do you know what else it can be?
SeraphimKidd
Sep 14, 2009 07:53 AM
redboy183
20
Jan 1, 2008 07:05 PM
hatchinprogress
Feb 15, 2006 10:22 AM
veggiemaster
Dec 15, 2003 03:15 PM
shadowstylz
Jul 21, 2003 05:41 PM
