Usdm gsr and Jdm gsr
Old Oct 30, 2016 | 01:22 PM
Justlearning95's Avatar
Default Usdm gsr and Jdm gsr
is there any difference between the usdm gsr and the Jdm gsr ?
Old Oct 30, 2016 | 03:12 PM
fcm's Avatar
fcm
Old Fart
Default Re: Usdm gsr and Jdm gsr
Do you mean other then the obvious, the JDM is right hand drive? 94
Old Oct 30, 2016 | 04:15 PM
im talking about the performance , usdm and Jdm gsr's have the same working conponents and performance correct?
Old Oct 31, 2016 | 05:13 PM
turbociv910's Avatar
yes there is between obd years
Old Nov 2, 2016 | 02:19 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
God it's been awhile.
I think the JDM GSR may have different cams, but don't quote me on that.
No knock sensor on JDM motors.
Most JDM motors have different pistons that are higher compression, but I actually think the GSR may be the same.
They are pretty much the same thing.
Old Nov 3, 2016 | 02:33 AM
HondaPartsHero's Avatar
Technical Hero
JDM B18C
SiR-G/GSR
  • VTEC
  • Found in:
    • 95-98 JDM Honda Integra SiR/SiR II (DB8, DC2)
    • 98-99 JDM Honda Integra SiR-G (DB8, DC2)
      • Identification: Black valve cover with dual runner intake manifold
      • Red Line: 8200 rpm
      • Rev-Limit: 8484 rpm- 8550 rpm (*For some only, most newer model SIR/SIR-G cut off at 8254 rpm)
      • Power: 132.5 kW (180 PS; 178 bhp) @ 7200 rpm & 126 lb·ft (171 N·m) @ 6200 rpm
      • Displacement: 1,797 cc (109.7 cu in)
      • Compression: 10.6:1
      • Bore: 81 mm (3.2 in)
      • Stroke: 87.2 mm (3.4 in)
      • ECU code: P72
      • VTEC Engagement @ 4500 rpm
      • Transmission Y80 (with optional LSD)
B18C1Edit
  • DOHC VTEC
  • Found in:1994–2001 USDM Integra GS-R (DC2)2dr (DB8)4dr
      • Compression: 10.1.:1
      • Rod Length: 140.0 mm (5.5 in)
      • Rod/Stroke Ratio: 1.58
      • Power: 170 hp (127 kW) @ 7600 rpm
      • Torque: 128 lb·ft (174 N·m) @ 6200 rpm
      • Redline: 8000 rpm (Fuel Cut-off @ 8200 rpm)
      • Secondary Runners Open @ 4400 rpm
      • VTEC Engagement @ 5800 rpm
Old Nov 3, 2016 | 02:44 AM
Technical Hero
FFS Tech | B-series Piston Check
more than likely you can find minimal cam profile differences and prob a slightly more aggressive P72 ECU tune
Old Nov 5, 2016 | 06:39 PM
v4lu3s's Avatar
RTFM
biggest differences i know of is the slight compression difference and often jdm engines do not have a vtec pressure sensor.
VTECcnIT
Feb 13, 2006 12:13 PM
calvinPGMFI
Apr 8, 2004 12:57 AM
xcivic_ex
May 30, 2003 09:36 PM
01nhbgsr
May 30, 2002 03:58 PM
NewbieGuy
Sep 2, 2001 10:42 AM
