Honda CR-V & Element 2WD & 4WD Element & CR-V
duplicate key for 2004 honda element ex
Old Oct 27, 2016 | 04:00 PM
TimRothermel's Avatar
Icon5 duplicate key for 2004 honda element ex
I heard that i can only get a replacement key for my 2004 element from the dealer
i called the dealer and they want 250 dollars for a single key to "program" it
does anyone knwo if there is a cheaper after market ket that i can buy for my element
Old Oct 29, 2016 | 09:50 PM
EJ8_Man's Avatar
Default Re: duplicate key for 2004 honda element ex
I googled this as I am curious about making another key for my 2006 CRV. There are DIYs on you tube for programming the fob. A blank key will cost $20-60. The blank will need to be cut by a locksmith (Walmart). The fob will need to be paired with your vehicle - this is where the "programming" happens. You can do this manually by following a sequence of actions
I found this, but have not tried it.
How to program Honda Remote Keyless Entry
I believe this is your key without the fob
http://m.ebay.com/itm/Honda-Transponder-Chipped-Key-Blank-Ignition-Free-Shipping-w-Tracking-H1-/321094914427?fits=Year%3A2004%7CMake%3AHonda%7CModel%3ACR-V&hash=item4ac2bf917b%3Am%3Am5QB72KYx9y9plhG31Y4I1g&_trkparms=pageci%253A3f65b68e-9e63-11e6-a989-74dbd180c7e4%257Cparentrq%253A1419b30e1580a2a39861ca39fffd5184%257Ciid%253A4
I believe that the key and the fob need to be programmed separately. I may be wrong for keys that function as both (like mine). Maybe only Honda can program the non-fob transponder only keys.
Edit:
After more reading apparently only Honda can program the key transponder unless you spend $70 on this piece of hardware, which I just saw work on a 2006 Accord via youtube
http://m.buyobdtoolshop.com/wholesale/new-sbb-key-programmer-v33.html
https://m.youtube.com/watch?v=iHkjXekiGBs
So if Honda is charging 250, you can DIY this for ~100 and you can keep the tools when you're done. Then list your new abilities on Craigslist and make a fortune
kadar
Jan 27, 2018 10:45 PM
Woodstock1969
Sep 10, 2016 07:49 AM
tysonnero
Dec 14, 2014 06:11 PM
wantathonda2009
11
Jan 2, 2009 03:07 PM
