Iab circuit in ecu keeps burning up.
Hello all.. i've searched and searched but can't find any information on this issue. A friend of mine has a 92 prelude with h23a1 she recently replaced the trans and a couple days after her ecu burnt up. Originally I figgured she shorted something out hooking things up with battery in but after replacing the dead ecu she was getting code 0 (bad ecu) and come to find that one burnt up the iab solenoid circuit (both ecu's burnt up the same) i've suggested testing the wiring for shorts with multimeter but my question I need answered is.. how do you test the iab solenoid itself in order to see if it's the cause of the burnt ecu's?
Easiest way, unplug it and see if it happens again, as the solenoid is out of the equation.
But, seeing as there was just work done on the car, I would lay money that a wire got pinched or nicked, and is grounding out causing it to blow. I would start by visually checking all of the wiring in the engine bay, specifically the harness going over the trans and under the intake manifold. If nothing is obvious, start testing wires for continuity, and jiggling them around while testing if not getting anything odd right away.
nycpatron
Mar 1, 2010 02:14 PM
lsjon
Engine Management and Tuning
May 30, 2008 08:41 AM
wanted to ask because I really don't want to see he fry a third ecu...
