Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Can I bypass the ac compressor on a 2007 Honda Odyssey?
Old Oct 26, 2016 | 08:19 AM
Mike Beachy's Avatar
Default Can I bypass the ac compressor on a 2007 Honda Odyssey?
The clutch stopped working on my ac compressor and I would like to just bypass the entire system. Is there a bypass pulley that is compatible with my vehicle, or is it possible to get a shorter serpentine belt that simply eliminates the pulley altogether?
Old Oct 27, 2016 | 09:06 AM
TyGuy88's Avatar
Default Re: Can I bypass the ac compressor on a 2007 Honda Odyssey?
If the clutch is seized up then yes, I'm sure you could get a shorter belt. May have to get a little creative but it can be done. If the pulley still spins freely there is no reason to bother with it. I would just pull the AC relay to ensure it doesn't engage by mistake. The pulley should offer no more resistance than a basic idler.
Old Sep 28, 2019 | 12:15 PM
Joe Don Quinn's Avatar
Did you ever find out how long of a serpentine belt you used to bypass the compressor? I have the same exact problem but I can't get to the vehicle to measure the path
jasunas
Oct 24, 2015 11:26 PM
boostlude
Oct 19, 2005 02:00 PM
4drDA
Aug 15, 2005 02:45 PM
ophdehEEzY
May 6, 2003 09:08 AM
