2000 Accord ECM question
Old Oct 23, 2016 | 04:12 PM
Helldawg's Avatar
Default 2000 Accord ECM question
I have a 37820 p8c a53 ECM and I see on other places they can be interchanged with several different numbers, but Honda dealer parts tells me they can only be replaced with the exact same ECM. Is this true and if not can it be straight swapped and disable the ignition cutoff module easily?
Old Oct 24, 2016 | 05:38 PM
GhostAccord's Avatar
Default Re: 2000 Accord ECM question
They can be interchanged as long as the ECU is for the same engine and transmission setup. As far as the immobilizer is concerned, there is no easy work around. In saying that, there are locksmiths that offer key fob programming at a cheaper price than the dealership.
Old Oct 27, 2016 | 10:27 AM
Helldawg's Avatar
Thanks. I took one to dealership, they took 2 hours to get to it, said it wouldn't communicate and charged me $75. Same dealership that told me it had to be the exact same number to work.
Old May 18, 2017 | 01:30 PM
MRT64's Avatar
2000 accord 3.0 V6
PCM ECU ECM 37820-P8C-A53 original part
have 2000 accord
PCM ECU ECM 37820-P8C-A54
How can I back reference the second ECU number to see if drivetrain is a match?
Old May 18, 2017 | 02:51 PM
holmesnmanny's Avatar
normally when they have just the last number sequentially off then they are essentially the same
Old May 18, 2017 | 04:48 PM
The last number is the version. So the 3 vs 4 could possibly have some emissions or fuel table changes, however as far as wring up and running your engine, they are the same.
Old May 18, 2017 | 04:53 PM
MRT64's Avatar
Thanks, thought that was the case after much resourcing of info. Amazing how much cross over (and under) info you get on these cars. Have gotten it to turn over and most everything is lit up and working. Do not hear fuel pump picking up though, been sitting a good while (about 4yrs) so not actually surprised. Now need to consider the key interaction and what is needed to make sure it is working.
Do we know if we are getting turn over, if key is passing the test or the no crank possible symptom of key?
Old May 18, 2017 | 05:13 PM
MRT64's Avatar
OK, if the emission table is different then is there a next step your aware of that I will need to pursue to correct? Or any direction to research further than wading through GROOGLE! (:.} GOOGLE)
Old May 18, 2017 | 05:39 PM
They are plug and play no additions or modifications required!
Old May 18, 2017 | 05:43 PM
MRT64's Avatar
��thanks will chase it tomorrow.
SDHonda153
Apr 12, 2018 04:25 PM
BlackHXCoupe
Sep 4, 2011 06:03 PM
kofimark
Nov 18, 2004 05:25 PM
lucas
Dec 27, 2002 07:05 AM
