jdm b16 or b18b???
Hi. I'm stuck on which one to go for right now. The engine is gonna go into a civic dx coupe. I have enough for either and want to get the motor in before it gets any colder up here in MN. I also want to know what the people with these motors think of it... My goal is a low 14s car. Thanks
Go B16B then drop a GSR or ITR crank, then get ur high compression pistons for all motor or lower for boost... Then you got a little B16 block that is a 1.8 hehe... If I had that block I would drop an ITR crank in it have GE sleeve it to 83mm and boost it..
[Modified by JDMspecEG6, 5:12 PM 11/8/2002]
I'm sort of thinking about boost later on.. Can the b16 handle boost that well compare to the b18b? The only thing I really want from the b16 is the big o'Dohc VTEC on the valve cover... I don't know it just screams bad ***. Is there a difference in installation since the b16a are from 92-95 civic's over in jdm land? Thanks..
the_0ne
17
Oct 30, 2003 03:09 PM
