92 Accord LX wagon where all the wires are run! Real life schematic with pictures
Old Oct 20, 2016 | 07:17 PM
ced715's Avatar
Default 92 Accord LX wagon where all the wires are run! Real life schematic with pictures
I meant to type "EX" in the title not LX sorry
I would imagine not every wagon owner has gone this far chasing down a wiring problem, but if you needed to know where to go, this might be a good reference as far as where the wires are run. At this point I had already started pulling the harness, so originally the wires ran underneath a lot of those braces that they are laying over in the pictures, but this is the path they follow through the passenger compartment.
I added some red circles where there was some nasty corrosion on some of the pins in the harness. If someone was having some nasty electrical issues towards the back end, these might be trouble points to dig down to. Also as a side note the ABS controller module connected to the harness just to the right of the top red circle. In between the red circle and the hatch for the fuel pump harness.
This is a closeup of the very rear passenger compartment of the wagon. This connector even had wires broken off. I know those in the rust belt are at greater risk to this kind of problem than others, but again, if you have rust holes starting behind the rear wheels your wires will be at risk!
Not a whole lot of specific information here, but hopefully some poor wagon mechanic can use this as reference in the future. Good luck!
Last edited by ced715; Oct 20, 2016 at 07:22 PM. Reason: The wagon is an EX not an LX
RTW DC2R
Apr 15, 2008 06:04 AM
JDM_EK_JOE
Oct 17, 2007 02:23 PM
dragonlord9
Audio / Security / Video
Apr 2, 2007 01:26 PM
r1ch
Dec 13, 2006 08:49 PM
redintheface
Apr 14, 2004 08:27 AM
