how to wire up H4 JDM headlights
Old Oct 16, 2016 | 03:27 AM
antigram's Avatar
Default how to wire up H4 JDM headlights
for all you guys wanting to install sir or singlebulb headlights
Old Oct 20, 2016 | 11:05 PM
crx_si-r's Avatar
Default Re: how to wire up H4 JDM headlights
easy but not correct way to wire them up. in order to properly wire up your h4/h4h headlights in a usdm chassis you need to add a relay.
why you ask allow me to explain.
usdm 88-91 civic/crx have 2 single filament bulbs.
jdm/edm 88-91 civic/crx have a single dual fiament bulb.
now here is why its not the proper way..on a usdm car the low beams stay on when high beams are activated. on a single bulb set up the low beams cut out when the high beams are activated. the way to make these work is to add in a relay. the realy will cut out the low beams when hight beams are actiavted.
Old Oct 21, 2016 | 10:44 AM
rallypoint_1's Avatar
^ That's a sweet looking harness!!!!
Old Oct 22, 2016 | 09:11 AM
crx_si-r's Avatar
thanks made it for a customer
rebel1988us
Feb 8, 2013 01:54 PM
ef yu
12
Dec 4, 2008 01:01 PM
FinallyGotMine
Aug 28, 2006 06:55 PM
JaEz
Jan 14, 2002 09:20 AM
