99 EM1 - OBD1 Alternator question
Hey all, so my 99 EM1 has a obd 1 alternator and don't ask me why, dumb dumb dumb previous owner wired it in, did I mention dumb....? Anyways I was wondering what obd 1 compatible alternators I need to swap in as my alternator is **** right now. It's the factory b16 as well.
No no no, and no.
DON'T cheap out on your alternator OP either go to Honda and get a brand new one, junkyard, or I even believe AutoZone carries the Nippon denso.
Only get Nippon denso..... Ask me why, I got about 4 reasons.
[QUOTE=White_EG1;51084177]No no no, and no.
Oh and about your obd1 issue any 94-95 del Sol VTEC, 94-95 GSR or 94-95 Ls one should do. You can even use a d series one but you have to modify the mounts.
Thank you all so so much, so the 92 93 integra obd 1 alternator won't work than? I saw that their cheaper than the 94 95 integra ones, is their a difference with pins in the plug cuz i know they are the same plug per say. We're jus tight on cash, single income parent :'(
- you can buy it at the dealer for $260 remanufactured . OBD2 ( Genuine Honda OEM Automotive Parts Catalog - Bernardi Parts ) ( 06311-P2T-003RM )
- More Information for DENSO 2100200 ( obd2 em1 denso ) ( $144 reman )
- More Information for DENSO 2100211 ( obd1 95 integra denso reman ) ( $145 )
- https://www.amazon.com/Denso-210-021...words=210-0211 ( denso reman for integra obd1 prime shipping $154)
Chino, the replacement was peanut butta cups, I pulled the alternator from the top, I didn't have to pop axles or half shafts. Only time I had to go under Neath was to loosen the bottom bolt of the alternator and disconnect the ckp sensor connector,I jus moved the harness above the alternator and a some brackets and Walla ;-)
