1991 CRX HF cat converter need help
Hey all im in the process of replacing my old original catalytic converter. These are the ones that bolt up right below the exhaust manifold. Ive already unbolted the 4 nuts at the top and just unbolted the 3 at the bottom right before the bend in the pipe(before the donut gasket). Now my question is do i have to unbolt the exhaust manifold to get it out? The cat is now just floating where its at. Seems like its hitting on the crossmember and the engine block when trying to get it out from below. How have others removed their old catalytic converters? TIA
Definately. The more i look at it, it seems the way to go..im wondering if i have to unbolt the manifold nuts in sequence? And is it necessary to replace the gasket while im at it? My first time removing a manifold lol
Generally speaking, engineering states work outside in when removing and inside out when torquing sequences are involved. It's not going to hurt following that rule of thumb if there isn't a definitive sequence to follow. And yes you should replace that gasket.
Thankyou thankyou! These little bits of info really do help me out. I appreciate the responses! My cat converter just came in so ill get back to work on it this weekend. Next ill be replacing my intake manifold for another oem piece thats not a caked up with carbon. Honda-tech rules! Love yall so much.
JDMhatchback20
Jan 19, 2005 12:39 PM
Red_Si
Nov 10, 2002 03:35 PM
