Honda S2000 Honda S2000
lowering S2K problem
Old Oct 12, 2016 | 11:09 AM
kingart's Avatar
Default lowering S2K problem
hi
i have XYZ Drift spec coilovers .... AP1 S2K ... 235/40 R17
I setup XYZ rear coilovers to max lowering without compression of springs but height is same as with original honda coilovers.
do you have any idea where is problem?
Old Oct 19, 2016 | 09:42 AM
KankakeeLocal's Avatar
Default Re: lowering S2K problem
Did you try driving the car for a while? I've had suspension setups stay looking a little high until i've released the e brake after fitting them or until after i've driven a little so the suspension can settle in a bit. Some suspensions don't do it as much but i've seen that as a solution for the strange and unexpected ride height after installing some coilovers or springs and shocks.
Old Oct 20, 2016 | 01:55 AM
kingart's Avatar
i drive with these coilovers very long
have S2k height at suspension geometry settings?
m.glisson003
Suspension & Brakes
Aug 6, 2011 01:49 PM
PoorBoy_96civic
10
Sep 26, 2010 08:37 AM
civic01coupe
Honda Civic (2001 - 2005)
Mar 7, 2008 02:34 PM
xlusiveracer
Jun 27, 2005 10:09 AM
alfaaay
May 23, 2005 01:51 PM
