T4 twin scroll 4 into 1 merge collector design help
Old Oct 12, 2016 | 05:51 AM
carlowerks's Avatar
Default T4 twin scroll 4 into 1 merge collector design help
I have no experience from the actual fabrication of it.
need insight from fabricators.
Is my design right?
i placed a 3mm thick(red) plate between the ports to separate the exhaust gases., i know for fact that these should not merge in a twinscroll design
attached are the pictures.
Old Oct 12, 2016 | 11:06 AM
FaceTuned's Avatar
Default Re: T4 twin scroll 4 into 1 merge collector design help
why not just cut the two pipes on one side each and do it the tradition method?
Old Oct 15, 2016 | 03:12 PM
aluthman's Avatar
Make two 2-1 collectors and then weld them onto the flange at an angle.
This is the collector I made for my manifold.
Old Oct 17, 2016 | 05:36 AM
carlowerks's Avatar
Thankyou so much aluthman! how many lbs of boost are you running?
i found this on youtube
Old Oct 20, 2016 | 03:58 PM
aluthman's Avatar
Right now I'm still on the base tune at about 23psi. Eventually I'll end up in the high 20s or low 30s depending on how the turbo responds. EFRs don't like being overspun, so I have to be careful.
rice a roni
Mar 21, 2013 06:12 AM
AdamB18C1EK
Feb 7, 2007 03:40 AM
digitalcongo
Nov 11, 2006 12:07 PM
Willard
15
Aug 5, 2003 07:23 AM
TurboInteg95
Aug 7, 2001 06:21 PM
