MARYLAND/Bowie area :5th&6th Gen Civic Parts/Car+Motor Sale (56Ker's BEWARE!)
DEAR MODERATORS: I just realized I did not post my username next to the items I posted up for sale. Understand That I have been gone from this website for a looooong time, so I didn't know the rules before posting. Most of the stuff I have posted are packed up and ready to be sold and it would be a real pain in the *** if I had to unpack most of it just to retake the photos and go through the process of posting everything up again with descriptions (I'm working with a sloooow computer). SO PLEASE DON'T CLOSE/BLOCK MY PAGE!!!!!!
Thanks for hearing me out and I hope you understand.
WAH GWAN HT!!!!
Thanks for stopping by It's been awhile but I'm back. Unfortunately I'm leaving the Honda game and moving on, so I'm here to let go of most if not all of the parts I have collected over the years for the project I never really got to get off the ground (my loss your gain). Most of the parts I'm selling are brand new (never used) and some are used but in good condition.
-PLEASE LEAVE A BUMP FOR LOOKING!!!!-
If anything catches your interest you can reach me by DM'ing me, Calling or by Email!
Cell:301-509-0369 my name is Sean (Pronounced SHAUN not SEEN)
Email:epicgaijin@gmail.com
WARNING!!!!!
I don't respond to text messages! So if you try to text me you will be ignored!
And last) DON'T WAIST MY TIME (or yours) IF YOU'RE NOT SERIOUS ABOUT PURCHASING SAID ITEMS!!!!!!!!!!!!!!
Now that that's out the way let's begin.
First the big one!
96 Civic Hatch with a B16B swap!
I purchased this car from a gentleman in PA with the motor swap already done. Currently the chassis has about 324,584 miles (and climbing due to this car being my daily) on it, unfortunately I do not know the mileage on the engine/trans but it does run strong!
-The body needs some serious TLC both rear quarter panels have rust as well as the passenger side door.
-Front windshield has a decent size crack in it (Do realize to pass inspection you will need to get the windshield replaced).
-Passenger side inner CV boot is torn (you will need to either replace the boot or change out the right axel)
-The belt for the power steering is worn (will need to be replaced)
-Rear of the car has been completely gutted.
-NO A/C AT ALL (A/C system has been completely removed)
-Shift linkage bushings are worn
-Being that the engine is a B16b you wont be able to pass emissions (at least in MD). I have heard you can swap the ecu with one from a usdm civic si to pass the obd2 test but that's up for you to do the research to see if it's true or not!
-AGAIN THE MILAGE ON THE ENGINE/TRANS IS UNKNOWN!!!!!!!!!!
-Brakes are worn.
Asking price is $1800obo
SIDE NOTE:
:Yes I do realize the bar code on the engine stamp is etched out, I have no idea why. If this is a big concern for you I understand. Just realize that I'm an honest seller trying to make a healthy buck (TALK IS CHEAP, I KNOW)
BRAND NEW: B16 Megan Racing Header (exhaust manifold)-$100FIRM
Rebuilt/Refurbished Complete 92-95 front subframe, rebuilt steering rack with (brand new never used) Quaife quick rack and pinion steering ratio kit installed w/ (brand new) hasport rear T-bracket mount!
- Rebuilt by me but never got the chance to install it. As you all know, stock out of the box the steering gear ratio for civic's (at least pre 2000's models) are trash so I opted for a quick ratio kit to fix that.
-Again this is a 92-95 5th gen setup BUT!!!! It will bolt right up to a 96-00 6th gen chassis as well but you will need to change out the T-bracket to make it work......EZ!
-NO I WILL NOT PART OUT!!!!!
$275,FIRM!!!
Brand New: EK9 Civic Type R Rear Bumper Support
-Keep in mind this is the fraction of the weight that usdm civic's have BUT because it's lighter/smaller it probably won't help if someone smashes you from behind so you should probably use this for track use only (but hey you're going to do what you're going to do right)!
$60,FIRM
Brand New: B-Series Oil Pan With Password JDM baffle Kit Installed
$55,Firm
Used: JDM Integra Type R Brake Master Cylinder+Brake Booster
-The brake booster will bolt up no problem, But know that if you're interested in the brake master cylinder you will need to reconfigure one of your brake lines, seeing as this is a JDM brake booster and not a USDM one.
-YES I am willing to separate!
$100 for both/ $50 separate, FIRM!
96-00 Civic Hardrace Front Sway Bar (Anti-Roll Bar) End-Links
-Keep in mind this will bolt right up to any civic with a 99-00 SI sway bar installed with SI lower control arms to match.
$35, FIRM
Brand New: Complete 96-00 Civic Hardrace Motor Mounts
$100, Firm
Brand New: 96-00 Civic Blackworks Rear LCA's
$95, FIRM
Brand New: Front Sway Bar Brackets
$10, FRIM!
Brand New: Front Sway Bar Bushings
$15, Firm!
Brand New: Front Sway Bar Bracket Bolts
$15, FIRM!
Brand New: 92-00 Civic Golden Eagle Brake Master Cylinder Brace
$90, Firm
Re-painted: D-series T-bracket
$60, FIRM!
Used: B-series T-bracket
$60, FIRM!
Brand New: 92-95 Civic/ 93-97 Del Sol/ 94-01 Integra Blox Front Subframe Rigid Collar Kit
$80, FIRM!
Brand New: 99-00 Civic SI Hardrace Front LCA Bushings
$49, FIRM
Brand New: 92-00 civic / 94-01 Integra Hardrace Rear Trailing Arm bushings
$65, Firm
Brand New: 92-00 Civic / 94-01 Integra Hardrace Roll Center Adjuster (lower ball joints)
$95,FIRM!
Brand New: 99-00 Civic SI Russell Steel Braided Brake Hose Kit
$80, FIRM!
Brand New: 99-00 Civic SI Russell Steel Braded Clutch Line
$25, FIRM!
Brand New: 99-00 Civic SI Rear EBC Red Stuff Brake Pads
$80, Firm!
Brand New: 92-00 civic Ingalls Engine Torque Damper
-Fits both B and D series engines!
$100, FIRM!
Brand New: 96-00 Civic D-series Shift Linkage Bushings
$5.00, (are you really going to try and haggle the price lol!)
Brand New: 96-00 Civic Buddy Club P1 Camber Kit (Front+Rear)
$250, FIRM!
Brand New: Blox Magnetic Oil drain Plug
$10, FIRM!
Brand New: 2 OEM 96-00 Civic Front bumper Hole Covers (Silver Color)
-If you plan on rolling without your front tag on, then these will cover up those unsightly holes (A cheaper option than taking your front bumper to a body shop to be sanded and painted)
$10, FIRM!
Brand New: 99-00 Civic SI 2 Pic Performance Front LCA Bushings (The pieces that connect to the subframe)
$30, FIRM!
Brand New: EK9 Civic Type R N1 Crank Pulley w/ Belt
$90, FIRM!
Brand New: 88-00 Civic Hardrace Rear Toe Adjusters
$75, FIRM!
Brand New: 99-00 Civic SI EBC Red Stuff Front Brake Pads
$80, FIRM!
Used: 96-00 Rear ASR Spherical Endlinks
$35, FIRM!
Brand New: 96-00 Civic Side Markers w/ Wires
$35, FIRM!
Brand New: 96-00 Civic Energy bushing kit
$80, FIRM!
Used: Starter (came off a B-series Motor)
$45, FIRM!
Brand New: 99-00 OEM Civic SI Rear E-brake (parking brake) Cables
$95, FIRM!
Used: 96-00 J's Racing Front Tow Hook
$65, FIRM!
Re-painted: 96-00 Civic EX Front shock Forks
$35, FIRM!
Used: Civic EX Brake Master Cylinder
$45, FIRM!
Used: 96-00 Civic Tegiwa Brake Master Cylinder Brace
$40, FIRM!
Brand New: 96-00 Civic Authentic Spoon Sports Rear Trailing Arm's Rigid Collar Kit
$100, FIRM!
Used: 96-00 Civic EX Proportioning Valve
-If you plan on installing rear (disc brakes) trailing arms from a EX trim or SI trim model then you'll need this.
$30, FIRM!
Brand New: 99-00 Civic SI EBC Rear OEM Replacement Rotors
$80, FIRM!
Used: 96-00 Civic EX Front Brake Calipers
-I think the Front EX Calipers have the same dimensions as the 99-00 Si front calipers
$65, FIRM!
Used: Beaks Subframe Reinforcement Brace
$35, FIRM!
Used: 96-00 Civic ASR 26mm Swaybar+Subframe Brace w/ Hardrace endlinks
$110, FIRM!
Re-painted: 96-00 EX Front L/R Side Knuckles
$55, FIRM!
Used: 96-00 Civic EX Front Wheel Hubs w/ Extended Studs (The studs are new, never had wheels or lug nuts mounted on them)
$45, FIRM!
Brand New: 99-00 Civic SI SP Engineering Front Slotted Rotors
$100, FIRM
New: 96-00 Civic Buddy Club Super Low Down Seat Rails (Driver Side ONLY)
-Was installed once just for test fitting!
$95, FIRM!
Used: 99-00 Rear Disc Brakes (trailing arms)
$90, FIRM!
Brand New: 92-00 Civic EX Front Wheel Bearings
$50, FIRM!
Used: 99-00 Civic SI Front LCA's
$85, FIRM!
Used: 96-00 Civic OEM Hatch Cargo Cover
$65, FIRM!
Brand New: 96-00 Civic Hatch Replacement Rear Quarter Panel (Drivers Side!)
$40, FIRM!
Re-painted: 99-00 Civic SI OEM Front Sway Bar
$65, FIRM!
Used: 96-00 Civic Hatch Password JDM Rear Lateral Trunk Brace
$65, FIRM!
Used: 96-00 Civic Rear Password JDM Strut Tower Bar
$65, FIRM!
Brand New: 96-00 Civic Password JDM Front 2-Point Strut Tower Bar
$75, FIRM!
Used: 96-00 (Authentic) JDM EK Amber Clock w/ Harness
$60, FIRM!
Brand New: 96-98 Civic (Authentic) JDM Cup Holder (RARE)
$65, FIRM!
Used: 96-98 Civic Usdm Left Hand Drive Optional Ashtray (Light Grey) (RARE)
$70, FIRM!
Used: 96-00 Civic Complete Genuine, OEM Floor Mat Set "FRESH" (just one slight blemish on the drivers side front logo)
$55, FIRM!
WAH GWAN HT!!!!
WARNING!!!!!
First the big one!
-Brakes are worn.
SIDE NOTE:
$275,FIRM!!!
$60,FIRM
$55,Firm
$35, FIRM
$100, Firm
$95, FIRM
$10, FRIM!
$15, Firm!
$15, FIRM!
$90, Firm
$60, FIRM!
$60, FIRM!
$80, FIRM!
$49, FIRM
$65, Firm
$95,FIRM!
$80, FIRM!
$25, FIRM!
$80, Firm!
$100, FIRM!
$250, FIRM!
$10, FIRM!
$10, FIRM!
$30, FIRM!
$90, FIRM!
$75, FIRM!
$80, FIRM!
$35, FIRM!
$35, FIRM!
$80, FIRM!
$45, FIRM!
$95, FIRM!
$65, FIRM!
$35, FIRM!
$45, FIRM!
$40, FIRM!
$100, FIRM!
$30, FIRM!
$80, FIRM!
$65, FIRM!
$35, FIRM!
$110, FIRM!
$55, FIRM!
$45, FIRM!
$100, FIRM
$95, FIRM!
$90, FIRM!
$50, FIRM!
$85, FIRM!
$65, FIRM!
$40, FIRM!
$65, FIRM!
$65, FIRM!
$65, FIRM!
$75, FIRM!
$60, FIRM!
$65, FIRM!
$70, FIRM!
$55, FIRM!
UPDATE:SOLD ITEMS!!!!
Hardrace Front End Links: SOLD!
ASR Rear Spherical End Links: SOLD!
Beaks Reinforcement Bar: SOLD!
Front Wheel Hub w/ Extended Studs: SOLD!
Moter Mounts: SOLD!
Front Strut Tower Bar: SOLD!
Rear Strut Tower Bar: SOLD!
Skunk 2 Drain Plug Set: SOLD!
Honda Bond: SOLD!
Megan Racing Exhaust Manifold: SOLD!
ASR Subframe Brace w/ 26mm Swaybar: SOLD!
92-95 Front Subframe w/ Steering Rack: SOLD!
Car/Engine: SOLD!
Moter Mounts: SOLD!
Honda Bond: SOLD!
Car/Engine: SOLD!
UPDATE:2
(MORE ITEMS FOR SALE)
SKUNK2 Magnetic Drain Plug Set
$25, FIRM!
SKUNK2 B-series Cam Seal w/ Honda Bond
$30, FIRM!
OEM B-series Oil Pan Gasket
$20, FIRM!
Energy B-series Shift Linkage Bushings
$10, FIRM!
OEM B-series Thermostat
!20, FIRM!
OEM B-series V-tech Solenoid Gasket
$15, FIRM!
IPG Parts Metal Shift Linkage Bushing (NO PLAY AT ALL) w/BOLTS
$25, FIRM!
DownStar Dress Up Header Hardware Kit (B/D/H Series Engines)
-This kit replaces your original exhaust manifold studs for a more flush cleaner look!
$30, FIRM!
$25, FIRM!
$30, FIRM!
$20, FIRM!
$10, FIRM!
!20, FIRM!
$15, FIRM!
$25, FIRM!
$30, FIRM!
Yeah, but depending on where you're located I could meet you halfway.
What part were you interested in?
The car does have a clean title. As far as rust under the car goes, there's a bit of it on the core support as well as the pinch welds.
If you live far and are still interested in the parts I'm selling I will ship. Just know that shipping will up the cost!
Figured I'd try something to get these parts moving/sold faster so........ This week only until friday, I'm open to all best offers on every part listed for sale!
If something interest you don't hesitate to ask.
