Rotate 3 teeth? - Timing belt tension
Old Oct 11, 2016 | 12:17 PM
lllelementlll's Avatar
Default Rotate 3 teeth? - Timing belt tension
I would like to confirm that I understand one of the instructions in the timing belt tension adjustment from the Helms manual.
I installed the new belt and rotated the crankshaft counterclockwise 4 rotations to set the belt on the gears and brought it back to TDC. Both cams were at TDC and the line on the crank gear was in line with the arrowhead on the oil pump (covers are off). I've also loosened the adjusting bolt.
My question is about the next step where you actually put tension on the belt. The instructions say to "Rotate the cranckshaft counterclockwise 3 teeth on the camshaft pulley". I'm unclear on what "rotate 3 teeth" means. In the picture I've attached, the third tooth past the TDC mark on each cam is now facing the other. Is this what it's supposed to look like?
1997 Integra GSR B15C1
Old Oct 12, 2016 | 07:06 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Rotate 3 teeth? - Timing belt tension
Thats not on right the timing is way off!
Old Oct 13, 2016 | 06:08 AM
rollinmyda's Avatar
Yes, once you are at tdc you loosen the tensioner and allow it to "snug up" on the belt, rotate it to the point in your picture, then tighten it to spec. Done
Old Oct 14, 2016 | 11:27 AM
Thanks for the reply, WF. This picture isn't at TDC. The crank has been turned almost a full revolution to move the cam gears 3 teeth. I watched your video and DaringBeefcake did the same thing at 7:30. Appreciate you posting it.
Thanks, Rollin. Got it back together last night and it's running well. Appreciate you confirming.
Old Oct 15, 2016 | 04:49 PM
tony_2018's Avatar
Fish Twig
You're suppose to do the following
1. slip on the belt with all timing marks lined up
2. tighten tensioner
3. rotate crank 1 full revolution to verify all marks are dead on.
4. loosen tensioner bolt 1/4 turn
5. rotate crank 3 teeth
6. tighten tensioner bolt.
Thats what I've always done and it works.
b00st Junkie
Jul 24, 2010 07:29 PM
Bright13
Classic Hondas
Mar 26, 2009 02:05 PM
chromeBuddha
Aug 4, 2008 12:43 PM
yosuthnmasa
Apr 8, 2008 07:29 AM
Seedc2
Mar 22, 2005 04:53 PM
