EG6 Civic VTi - Darton Mid Sleeves Temperature Problem
Old Oct 11, 2016 | 12:16 PM
Ballestrini's Avatar
Default EG6 Civic VTi - Darton Mid Sleeves Temperature Problem
Hello all,
I bought a EG6 with a sleeved b16 block, but now i have many temperature problems. Always when i get high revs (2 or 3 gears) my car hits 100º C.
Im using a koyoard radiator, one original fan and other 10" auxiliar fan, OEM Honda Radiator fluid. Everytime when i run fast i turn on the two fans but its not enough, i mad a jump button.
Im using s300 v2, it dont have the same protection of v3.
i dont know what to do.
Old Oct 11, 2016 | 02:10 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default re: EG6 Civic VTi - Darton Mid Sleeves Temperature Problem
Please describe how you have two fans mounted on one radiator.
Old Oct 11, 2016 | 03:10 PM
98civdx's Avatar
Master Detailer
One pusher, one puller?
Have you ran a leak down test?
Old Oct 11, 2016 | 03:50 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Yeah, my thought is human error of facing the pusher towards the puller cancelling each other out.
Would be a pretty easy mistake to do.
Old Oct 13, 2016 | 10:02 AM
theYBLEGAL's Avatar
Loved
So you're car is turbo right? Where's the dump tube routed? Or the downpipe?
Usually the downpipe is too close to the radiator, and driving harder causes more exhaust heat. If you have a dump tube exiting in the exhaust, also be sure that it's dumping into the lower airstream and not directed at your radiator and/or oilpan. I've had the issue where the dump tube was too close to the radiator. After 2 laps of gingerman raceway, my temps would start going up.
Otherwise, it could be timing/tune related.
Old Oct 15, 2016 | 07:17 AM
Former User's Avatar
Default Re: EG6 Civic VTi - Darton Mid Sleeves Temperature Problem
B16a2 engine?
Some basic questions...
Bad thermostat or radiator? Air in cooling system? Coolant leak?
Narao
13
Nov 5, 2017 06:04 AM
FoRizzyy
Jun 5, 2012 06:53 PM
NickyB92HCivic
Oct 17, 2010 10:49 AM
Mattyg2
Jun 1, 2004 02:46 PM
imaginary17
Apr 5, 2004 10:38 AM
