Caught air hitting a semi truck tire on the freeway
Old Oct 10, 2016 | 03:29 PM
LightGesture's Avatar
Default Caught air hitting a semi truck tire on the freeway
I think it ruined pretty much everything..
Tore my lip off, the front left headlight assembly is shattered, so is the corner light.. left blinker clicks fast now..
front left fender well is missing, exposing some tank and an electrical something is hanging...
There is also a small rubber tube hanging that goes up towards the windshield, maybe it is the windshield wiper fluid? Don't know...
Installed a brand new exhaust, and now the catalytic converter shield is broken, rattling...
I give a little gas, and it now sounds like an exhaust leak, cause I hear a fart noise then abruptly stops after tapping the gas, sounds like it's right where the midpipe connects to the headers...?
Anyone know what the heck some of these parts are under the fender well? I guess I'm gonna zip tie all the goodies supposed to be hidden until I can get a fender well....
Can't believe it... I almost died...
I was going to replace the rack and pinion, axles, brake pads and rotors yesterday, but broke my ratchet so I figured it wasn't my day to work on the car... Guess God spared me from needing to replace new parts over again?
T.T; The dangling tube connects to this yellow reservoir, I believe it used to connect to another tube (out of frame) that went up towards the top back part of the fender.. that box, idk, it's broken, but I don't know what it is.. it's just dangling
Entire lip was torn off.... Peeled off the inner fender well with it...
Old Dec 21, 2016 | 10:33 AM
Raf99's Avatar
Default Re: Caught air hitting a semi truck tire on the freeway
Ummmm, windshield washer fluid reservoir, the hose is for the windshield washer fluid too. The electrical thing is either the pump for the washer fluid reservoir or a relay. Zip tie it all up there and you'll be good.
zach1288
39
Aug 3, 2007 08:22 PM
xxredpreludesixx
Sep 16, 2005 04:13 PM
JamesQ
Dec 13, 2003 10:46 PM
BlackGS-R
Jul 22, 2003 02:50 PM
UnrealSpeed
13
May 14, 2002 12:45 PM
